Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Old 11-18-2010
SeaQwest is on a distinguished road
Standing Rigging: Rod vs Wire
Fellow sailnetters,
I would be interested in learning the pros and cons of rod versus wire standing rigging methods.
I have always heard rod was better, but, if so, why? Do both require tuning at similar intervals? With "normal" use, how long could each be expected to last before all new rigging needs to be installed - 10, 20, 30 years?
I am sure this topic has been covered before, but I have not been able to find. As always, thanks for the education.
Jim
SeaQwest
Old 11-18-2010
Rod has pros and cons like any rigging.
Pros: Lighter, less weight aloft, lower windage, greater strength to weight ratio.
Cons: harder to inspect, can fail with little warning, harder to replace or repair in remote ports,
As for how long it lasts, it depends on whether you're on salt or fresh water, whether you sail year round or for just the sailing season, whether you race or just cruise, etc.
Wire rigging is heavier, creates more windage and has a lower strength-to-weight ratio than rod, but is easier to replace, can be replaced using all ship-board hand tools, is easier to inspect. You can easily carry spare wire-rope rigging, but carrying spare rod rigging is much more difficult.
Synthetic rigging, like Colligo's Dynex Dux-based rigging, is also a reasonable choice, but it is more expensive than wire rope or rod rigging generally. It is lighter and has a better strength-to-weight ratio than metal rigging, but is susceptible to being cut...
Old 11-18-2010
Thanks Sailingdog. I would have naively guessed rod to be the heavier of the two because it is suppose to be stronger and, of course, less flexible.
As for longevity, let's say the boat is docked in the northeast in saltwater, used 6 months a year as a coastal cruiser and never raced. Generally, I would assume the rigging, if wire, would be good for about 10 years. Would it be a significantly longer life span for rod rigging?
Which would be the more desirable rigging on a mid-size (35') coastal cruiser, occasionally bluewatered, never raced, mono-hull sailing vessel?
Wow...that "can fail with little warning" part is scary!
Thanks again.
Jim
SeaQwest
Old 11-18-2010
tommays's Avatar
Anything can fail without warning
We have rod on my friends the 35' and it was replaced at 20 ? some odd years of nothing but racing
The good thing is its Navtec and all top shelf stuff the bad thing is cost a LOT of money
The only real way to test the rod is to cut the end off and run it through the head forming machine
If it takes a new head its OK if not its BAD
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 11-20-2010
Thanks Tommays. 20+ years! It may cost more, but if you get twice the life span, it should be worth it.
Based on what I am hearing, rod seems to be the more desirable rigging.
Thanks.
Jim
SeaQwest
Old 11-20-2010
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
I have rod rigging on my CS36M. The boat has been down south for 8 trips so it's had salt and fresh water. Bought it in 1988, still going strong, 22 years. Kinked the forestay once when removing the mast, had to replace it. Other than that no problems. We remove the mast every fall and the rod rigging is a bit unwieldy compared with wire but you get used to it.
Rick I
Toronto in summer, Bahamas in winter.
Old 11-20-2010
Over the years we've had two rod rigging failures. One a D1 shroud, the other a deckstay, both on a 40 footer we owned previously. A quick tack saved the rig in the first instance.
Both failures were traced to seized rod end fittings in the turnbuckle barrel. (actually the deck stay had been welded to the turnbuckle... same effect) As it was explained to me, every time the load surges on a rig, eg going over a wave, there's a torsional stress applied (ie the rod twists and untwists a bit) The rod end is meant to move within the turnbuckle at this time. If the rod end is seized that stress 'works' the rod where it exits the turnbuckle, eventually failing there. Whoever welded our deckstay created the same scenario.
The rigging was, to our knowledge, original and about 15 years old at the time. We subsequently loosened the rig, opened up and freed all the rod ends, applying lanakote to keep the ends free and had no further issues - I believe the boat is still sailing today with the same rod, other than the replaced parts, now well over 20 years on.
There's lots to like about rod, but wire will often give you some warning, or more easily observed indication of pending failure.
1984 Fast/Nicholson 345
Old 11-22-2010
paulk's Avatar
paulk is on a distinguished road
We replaced our rod forestay a season back, when we put in roller-furling and found that the original forestay had a kink in it, hidden underneath the tuff-luff for we don't know how long. The rigger said the heads on the Navtec rod tend to crack through metal fatigue: repeated loading and unloading. He would have simply re-headed the original rod if it hadn't had the kink. We've raced our boat hard for the past 12 years, but she was built in 1981. We do look over the rig carefully each season, but not with dye or anything too fancy.
Things can break, anytime, of course. On a different boat I was on, we had a wire shroud suddenly let go in the Bay of Biscay, despite it's having been carefully checked over before the boat had sailed Transatlantic, up the Irish Sea to the Hebridies, and back down to the Gironde estuary.
Old 11-22-2010
TomKeffer's Avatar
TomKeffer is on a distinguished road
Navtec offers an excellent (albeit very conservative) guide to inspecting rigging, including guides to the life expectancy of rod rigging.
S/V Velocity
J/42 #39
Old 11-22-2010
It depends. If you are going cruising, I would recommend wire, not rod, rigging. You can't really carry spare rod rigging very easily. You can't adjust the length of it without specialized tools, where mechanical fittings--like Hayn HiMod, StaLok and Norseman--allow you to shorten wire rigging with only basic handtools.
Thanks.
Jim
SeaQwest
Q: Standing rig wire size ulferlingsson Gear & Maintenance 1 06-11-2010 10:17 AM
New Standing Rigging (wire) riphonda Gear & Maintenance 15 06-04-2009 02:36 PM
Wire Luff Sails (free standing furling) ranes Gear & Maintenance 2 07-04-2008 03:03 AM
which wire rope for hand press fittings / standing rig gjxj Gear & Maintenance 6 08-16-2006 11:19 AM
Standing rigging wire type ricekrgr Gear & Maintenance 1 03-28-2006 12:34 PM
