02-15-2011
Gray, since you are making a new one why not make it the right way?
Find an appropriate primer and top coat for whatever type of plastic you are using. Delrin, UHDPE, ABS...they all have speciic primers. Often available from auto body shop suppliers. And then pick a top coat preferably from the same manufacturer, which is compatible for use with that primer.
If the rudder is going to be kept out of the water most of the time, I wouldn't worry about the intended use of the paint. If it is going to be submerged for exended periods, you'll need a paint that is designed for submersion, or else it will wind up coming off.
All good reasons to use a white plastic and skip the paint, probably.
