Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
  #11 (permalink)
Old 08-01-2011
hellosailor's Avatar
"it'S not a matter of IF but WHEN the wire snaps."
A centerboard consists of a variety of moving parts subject to wear and corrosion, located in a totally inaccessible place under a hostile environment. What could possibly go wrong with that?!
There probably aren't any better alternatives to getting a shoal draft boat though, unless you start looking at multihulls. I keep reading that using the new synthetic lines instead of metal wire is a better way to go, that they will last longer and of course not be subject to the same corrosion problems. Either way, you need to consider preventive maintenance and change out the line on a scehdule before it needs to be done.
Catalina "Wing Keel"? TheWhiteRabbit Boat Review and Purchase Forum 28 09-13-2010 09:09 PM
Any reviews of Don Guillette's "Sail Trim Chart" or "Sail Trim User's Guide"? 0verdrive Learning to Sail 4 07-25-2010 10:16 AM
Centerboard and "full keel" on the same sailboat - why? Northbeach Sailboat Design and Construction 9 04-06-2009 10:23 AM
Bahamas at 6'11" sab30 Cruising & Liveaboard Forum 11 07-15-2008 08:40 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
