02-07-2011
The Grid
So what is a lofting board for? For lofting, of course.
Lofting is the process of blowing up the relatively small-scale plans you get from your naval architect (in my case, from William Atkin), into full size plans.
This process is thought to be so complicated that many modern architects supply full-size plans to eliminate the need for lofting. Just roll out the plans and start building. But if you don't know how to loft, you can't build about 98% of boats, because full-size plans aren't available.
Plus, you miss out on all the fun of lofting, which really is a kind of relaxing exercise, once you have all your hair torn out...
Read blog post: The Grid
Fair Lines: John
Check out my blog: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
