Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Old 02-04-2011
UnlikelyVoyager's Avatar
UnlikelyVoyager is on a distinguished road
UnlikelyBoatBuilder: Building the 10' Atkin Sailing Dinghy "Vintage"
Okay! It's finally time to get started on this winter's build!
The goal is to build the William Atkin designed "Vintage" in time for the "I Built It Myself" show at the Wooden Boat Show in Mystic, CT.
Why "Vintage"? Several reasons.
First, I think it's time I tackled a round-bottom boat. Again, I think this is a project that is way above my current skill level, but I'm a real believer in the adage that people can do more than they think they can. Just because I doubt my ability to build such a complicated boat, is no reason to not do it.
Sounds weird, right? Ah well...
Read Blog Post: Building "Vintage"
Clear lumber: John
Check out my blog:
Old 02-05-2011
Lofting Board
Now that I've cut out the two pieces of my lofting board, it's time to assemble it into one 3/4" x 4' x 13' surface. I also want to white-wash it.
The boat building books (BBBs) discuss lots of ways to assemble the lofting board. Probably the best way is to screw the various panels down on the floor. I didn't want to do this because I didn't want to drill holes in my floor, and also I wanted to be able to move the board if needed, or even lean it up against the wall to get it out of the way...
Read blog post: Lofting Board
Fair lines: John
Check out my blog:
Old 02-05-2011
RXBOT is on a distinguished road
Looking at your board in the room I am hoping you are able to get the finished boat out of the room. You will probably add a piece of strapping on the bottom to set your T square on maybe that will help hold it togeather also. I wonder if you added another at the top in case you wanted to measure down would be of any benefit.
Good luck & Good lines
Old 02-05-2011
Yes, the boat is only 10' long. I made the lofting board 13' so I could use 12' battens on the sheer line, etc.
No problems getting it out when I'm done.
Check out my blog:
Old 02-06-2011
WanderingStar is on a distinguished road
Sounds exciting, can't wait to see it.
Old 02-06-2011
deniseO30's Avatar
Lies about her age
Ah... one of my favorite little boats. Your definitely in for a learning experience. She is shown in traditional build. I'm sure she could be done in "glued lapstrake" and using only one or two sawn frames under the seat areas. Many glued lap boats have no ribs at all.
Some of the things that will be involved with a traditional build; Steam bending, a steam bent and rabbited stem, (one very difficult operation that sometimes can be done easier with a inner and outer stem) long skinny steamed ribs.(easy) Clinker and or rove and rivet fastenings.(extra hands help alllot) Fitting the planks to the stem is where many builders get hung up. You will need a rabbet plane like a Stanley 92
Spiling is not real difficult to learn, by all means have cheap luan underlayment on hand to use for patterns or temporary planks. Do you have a source for the white cedar? Oh.. then there are scarf joints if but you should be able to get white cedar in longer lengths. Red is very brittle and splits real easy. even though it's easy to source. Looking forward to your progress!
Old 02-06-2011
deniseO30's Avatar
Lies about her age
real slow and boring demo on cutting a stem rabbet.
YouTube - Cutting a stem rabbet
Old 02-06-2011
Yes, I haven't decided 100%, but I'm thinking of going glued lapstrake, with an inner and outer stem. I keep flipping back and forth between traditional cedar planking and glued lapstrake. I have time to decide, obviously!
-- John
Check out my blog:
Old 02-06-2011
Hey, where on LI are you? I'm in Huntington.
Check out my blog:
Old 02-06-2011
deniseO30's Avatar
Lies about her age
ML condon in White Plains would be the place for white cedar.
"Oily Pollution" and "MARPOL Trash" Placards? SEMIJim Gear & Maintenance 16 11-15-2011 09:39 PM
Dinghy "aero" PFD Recommendations ? rocketwench Gear & Maintenance 0 05-28-2010 06:38 PM
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 16 07-28-2008 06:11 PM
"Blue Water Boats?" "Rescues" snider General Discussion (sailing related) 37 07-01-2007 10:21 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
