Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Like Tree2Likes
  #21 (permalink)
Old 09-27-2011
If you were to carve a dugout canoe and not taper the ends your Cp would be 1.00.
(providing the log had no natural taper to it.)
The more you cut away to taper the ends the lower your Cp.
Thanks Bob.. that's essentially what I was thinking. Thanks for the book reference too.
1984 Fast/Nicholson 345
  #22 (permalink)
Old 09-27-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Jon:
No you were wrong when you started and you are still wrong.
Cp and rocker can be connected but really have little to do with each other.
Think of an inland lake scow, zero rocker, high prismatic.
Once more, quit trying to connect rocker a two dimensional measurement with volume a three dimensional measurement.
The Scampi and the Peterson half tonners would both have had very similar Cp's. Probably around .54. Trust me. You are still thinking two dimensionally.
Keep in mind, again, Cp involves both ends of the boat. You are bow fixated.
O/K Bob, thanks. Time for me to hit the design books again. It's sure good to have someone with your expertise to discuss this stuff with.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
  #23 (permalink)
Old 09-27-2011
grumpy old man
bobperry is on a distinguished road
Jon:
I just feel bad that I can't explain it better. If you were sitting here next to me, I'd pull out a roll of flimsy and in no time have enough diagrams to show you what I mean. But I have lost patience with my own inability to put it into words. Killing's book is the best and partly due to the most excellent illustrations.
Through Hull HorizonHunter General Discussion (sailing related) 8 09-17-2009 03:40 AM
Hull ID vs. hull number bristol321 Bristol 8 03-17-2008 09:01 PM
Multi-Hull vs Mono-Hull Sailboats? terryjoe Boat Review and Purchase Forum 8 11-11-2007 10:45 AM
Do you paint over thru hull bronze nipples on hull saurav16 Gear & Maintenance 4 08-19-2007 06:15 PM
New Thru Hull 1970Columbia34 Columbia & Coronado 1 02-25-2007 05:36 PM
