09-27-2011
Senior Moment Member
Originally Posted by bobperry
No. There have always been high and low Cp boats. The "Peterson bow" was no different from the Carter bow, the Holland bow or the S&S bow of the day. It had nothing to do with Cp and everything to do with girth differences. But due to the IOR's weighting of the forward depth measurements rocker was diminished. At the Carter office we called it the "clipper" profile referring to the rockerless profile of the old clipper ships.
Now, to your example, the old wineglass section hull. The calculation of Cp in that hull depended upon where the the designer said the hull ended and the keel began. It's not so obvious in this example compared to a modern fin keel boat.The question was: Do you include the keel in the Cp calc or do you not include it? But as long as the designer was consistant in determining how he would calculate Cp there was no problem.
Go sit by an entrance to a harbor where there are some steep waves building up. Watch the boats come and go. Note that boats with less rocker when they "buck" will pull a far greater amount of the hull out of the water than boats, say like a Westsail 32, will. Then the rockerless boat will slam the entire forward end of the boat back in all at once, pounding. The boat with lts of rocker will ease the hull back into the water and not pound.
That's about the best I can do without sitting down and drawing illustrations as explanations.
I hate to generalize but here I go: Heavy boats have more rocker and they resist pounding. Light boats have less rocker and they pound. Generally.
I hope that helps.
Got it. That's exactly how I expected it would be. I'm going to have to pull out my design books and study CP again - I seem to have missed something in that area.
Thanks.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
