10-07-2011
Senior Moment Member
Originally Posted by olson34
A well engineered and constructed boat will not routinely see a keel separating from the hull. Calling it a "smile" (or a frown) does not change this or make it acceptable.
Look for damage around the keel nuts inside if the keel hit a hard bottom. This can also cause the rear of the keel to push up and fracture parts inside, as well.
If, OTOH, the whole hull layup is weak enough to let the keel weight pull down at any point due to hull flexing, the repair will involve strengthening the whole attachment area.
Some production boats had some plywood incorporated into the sump area as bearing material for the keel nuts and washers, and that wood rotted over the years. Dropping the keel and building up the inside should fix that situation.
One other part of preventative maintenance that should be mentioned, is that it's good to drop the keel for inspection of the "bolts" every 15 to 20 years.
What make n model is this boat?
L
All valid info and the keel SHOULD be checked thoroughly BUT I doubt there are many (or any) people who would say that C&C boats were not well engineered or built. The "smile" is a result of the small mounting base area of high aspect ratio keels, particularly if they are highly swept. Absent any heavy damage from grounding or failing bolts, they are commonplace and nothing to worry about.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
