Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Like Tree1Likes
Old 10-17-2011
Ulladh is on a distinguished road
Bubble to reduce hull/water drag?
Air bubble cushion for bulk carriers to reduce drag. I wonder anything applicable to reducing sailboat hull drag? Maybe we will see something like this in a future Americas Cup boat.
Bulk Carrier to Ride on Bubbles to Reduce CO2
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Old 10-17-2011
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
My guess is the weight and space required by the equipment to produce a cushion of air bubbles would likely eliminate any advantage they produce in a sailboat application.
DivingOtter likes this.
"Clean bottoms are FastBottoms"
Old 10-17-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Cool idea. Maybe on a sailboat there could be an appendage that 'cavitates' air under the hull.
Old 10-17-2011
Fstbttms's Avatar
Sounds real slow to me.
Old 10-17-2011
Barquito's Avatar
Barquito
Probably. At the speeds of AC boats, maybe all it would take is an air scoop on deck that forces bubbles under the boat. Like a ram jet. Need speed to make speed. Although, I assume this would only be needed on displacement hulls anyway. Still, I like the idea of trickle-down technology from cargo ships down to AC boats.
Old 10-17-2011
Large Member
mdbee is on a distinguished road
Mach 1 torpedo
Supercavitating Torpedo | Popular Science
Old 10-17-2011
mitiempo's Avatar
It is not a new idea really. The late Lars Bergstrom and his partner Sven Ridder used it on Route 66 years ago. YW
Lars Bergstrom designed the unique rig on many Hunters and also the Windex at the top of most masts.
Brian
Old 10-17-2011
NateKing's Avatar
NateKing is on a distinguished road
Wouldn't this affect the buoyancy of the water causing the boat to float lower in the water?
Old 10-18-2011
mitiempo's Avatar
It is a very thin layer of bubbles. Wouldn't even be noticable.
Brian
Old 10-18-2011
Zanshin's Avatar
Zanshin is on a distinguished road
I flew a DG300 glider for a while which used the same principle, lots of pinhole sized holes in the wing which changed the boundary layer and transition from laminar flow. It was a great idea but one spent a lot of time before competition flights with a needle to unplug holes so I can imagine how difficult it would be to do the same thing underwater.
Reduce Heeling newinthewater General Discussion (sailing related) 24 07-02-2010 06:14 PM
Compass Bubble LarryandSusanMacDonald Gear & Maintenance 2 08-09-2009 04:02 PM
Rod rigging to reduce corrosion ? SvenG Sailboat Design and Construction 17 01-06-2009 07:43 AM
Question on fixed prop drag / hull speed Northeaster Gear & Maintenance 5 04-12-2007 07:26 AM
I have a bubble in my compass!?! CaptGentry Gear & Maintenance 5 01-25-2003 06:16 PM
