Gaff rigged cat vs typical sloop rig - SailNet Community
 3Likes
post #1 of 14 Old 02-21-2012 Thread Starter
Thinking about getting a trailerable sailboat in the 20 foot range and wondered about whether a gaff rigged cat might be better than a typical sloop rig? Advantages/Disadvantages ??
lancelot9898 is offline
post #2 of 14 Old 02-21-2012
FSMike's Avatar
A marconi rigged catboat would be simpler, less strings to pull and only one sail. A gaffer would have a few additional strings.
Neither boat would go to windward as well as a marconi rigged sloop.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #3 of 14 Old 02-21-2012
Senior Slacker
SlowButSteady's Avatar
True. However, a gaff-rigged (or a gunter-, or a lug-, or a lanteen-rigged) boat would have the advantage that the spars would all be shorter than the hull of the boat. That can make trailering quite a bit easier. A shorter mast is also easier to raise and take back down. Yes, one gives up a bit of performance by using one of these rigs with shorter masts. But, if speed is the only criteria, then a little ski-boat would be a better option anyway.
WanderingStar likes this.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #4 of 14 Old 02-24-2012
Tundra Down
downeast450's Avatar
We enjoy a Marshal Cat Boat, the Sandpiper. I like the gaff rig on this little boat. One sail to reef and it is huge! Down wind with the board up it flies. Scandalizing the gaff de-powers it quickly. It can't get much closer than 45degrees but so what. It is fun and we just plan around our up wind performance. I like the way it looks,too. Handling the spars is easy because they are relatively short. This is our (trailer sailor) and having a mast that isn't much longer than the boat is very convenient. I can still lift the mast into the step by myself. I wouldn't be able to do it alone for a larger boat but it would be simpler than a 25 foot stick.
Marshall builds a nice boat. It is very capable and probably the "largest" small boat available. Six adults can sit in the cockpit of our 15' boat!
We have an Islander-28, too. Both rigs are worthy.
Down
downeast450 is offline
post #5 of 14 Old 02-24-2012
Owl
-OvO-'s Avatar
"scandalize" ? this is an unfamiliar term.
-OvO- is offline
post #6 of 14 Old 02-24-2012
To scandalize a gaff sail you slack the peak halyard, (gaffs have two halyards) lowering the end of the gaff. This allows the upper aft portion of the sail to spill wind, effecting an emergency reef. I've done this in a squall, it's beautiful.
WanderingStar is offline
post #7 of 14 Old 02-24-2012
Tundra Down
It is one of my favorite commands! Ha! Provided that someone near the cleat knows what it means. It is very effective and sometimes necessary with such a big sail. We got overtaken by a squall line that was rolling down Somes Sound. Whew! The IODs were making a buoy turn in practice for the Worlds starting the next day. We were out there watching and all of us had an exciting time. The cat boat with a scandalized gaff may as well have been flying a spinnaker! With the board nearly up it flew away from the others. It was not particularly relaxing for a few minutes but the boat took it in stride.
Avast!
Down
post #8 of 14 Old 02-24-2012
Old Gaffer
FishSticks's Avatar
Marconi vs gaff rig on a catboat?
Would you add ginger ale to fine rum?
SloopJonB likes this.
Never sail closer to the wind in degrees than your age
FishSticks is offline
post #9 of 14 Old 02-24-2012
You are associating gaffs with rum and ginger ale with dilution of purity , right? Scandalous to think otherwise but tide lifts all vessels: even if Marconi rigged.
Capt Len is online now
post #10 of 14 Old 02-24-2012
Command 'Let fly the snotter' Blank stare.
24' custom built glass on ply gaff rigged sloop damage assesment Kmenex Gear & Maintenance 39 04-24-2011 04:55 AM
Gaff-rigged schooner on the Mobjack Thursday tri413 General Discussion (sailing related) 0 11-13-2010 01:48 PM
junk vs gaff rigged??? AKscooter Gear & Maintenance 8 12-21-2009 03:15 PM
Converting a gaff rigged sail sbleier Sailboat Design and Construction 5 09-27-2008 01:53 PM
traditional rigged Vs gaff rigged crosseyeddreamer Boat Review and Purchase Forum 9 04-02-2008 01:16 PM
