Mast wiring access panel - SailNet Community
post #1 of 3 Old 03-24-2012 Thread Starter
Tundra Down
downeast450's Avatar
I am doing some work on the base of my mast. I have never opened the wiring access panel before. Ten ss machine screws secure a rectangular aluminum plate in the side of the mast about 6 inches above the base. Since I was doing other work I decided to remove it and clean things up. Ha! Removing it is a bigger chore than I had anticipated.
After removing all the fasteners the only thing left holding it in place was the "sealant" that was used to bed it by the PO. It may be 5200?!! How in the world would I have gained access to the wiring with the mast up if I had needed to? I have "tapped", pried, added solvent and I have the mast lying on its side at waist level! My next effort will be to apply gradual pressure using a C-clamp while warming things with a heat gun. I expect even 5200 will give up. It goes back on with either nothing or butyl caulk. What a PITA it would have been to confront this with the mast up and the wires "in there somewhere" needing attention.
Can you get your mast wiring access panel off?
Down
downeast450 is offline
post #2 of 3 Old 03-24-2012
Re: Mast wiring access panel
Down, I needed an impact driver the first time I tried to remove an access panel. One of those tools you always figure would be real handy once in a great while. Sure is. It can really motivate philips head screws without smashing the slots up.
hellosailor is offline
post #3 of 3 Old 03-25-2012 Thread Starter
Tundra Down
Hello,
With some care all the screws cooperated . I thought having them removed was a real milestone in removing the panel. NOT! The visible bead of sealant looks like silicone but it sure acts stronger than I would have expected for old silicone. It is my plan to eliminate the inspection plate to make room for a couple of "cheek plates" to accommodate a new mast step / tabernacle. I would just weld it in place without removing it if it didn't have the sealant there. I need to clean it first.
If I were putting it back as a removable inspection panel I would use Butyl tape as a sealant, or none. Perhaps just a good smearing with Lancote?
Down
New 10W Solar Panel. Question Regarding Wiring (with pictures) liveincolor Electrical Systems 41 05-18-2012 04:56 PM
Solar panel wiring question remetau Electrical Systems 9 03-22-2012 08:43 PM
Mast Wire Race Access obelisk Gear & Maintenance 23 01-15-2012 10:45 PM
Adding an access hole in my mast etwilliams Gear & Maintenance 7 11-06-2011 09:46 AM
Solar Panel wiring HorizonHunter Electrical Systems 4 06-27-2010 08:28 PM
