Mast Step on an Irwin 43? - SailNet Community
post #1 of 4 Old 06-16-2012 Thread Starter
F15EWSO's Avatar
I'm looking at an Irwin 43 center cockpit that appears to have some compromised wood in a lateral stringer near the front cabin/head. A limber hole was drilled through the stringer just to starboard of the mast box to run a fresh-water hose underneath the sole. When they drilled they threaded the hose right through the limber hole and never sealed the wood/plywood. Since then the wood has absorbed water and part of the stringer "rings" dead with a hammer.
Access there is a bear, the surveyor and I are uncertain if the lateral stringer we see forward of the mast box is integral in the support of the mast or if it just mated or "sistered" up to the actual box/step that is the true support for the mast. The stringer could just support the molded plastic floor and the mast step/box is not really part of the compromised wood. There is a house bank battery tray in the way, we peeked in all the areas we could see but just can't tell if the stringers are "weight bearing" or if the mast step has its own supports actually beneath the mast itself.
I know this verbal description is a bit weak, what I'm looking for is if anyone has an idea of what the actual construction is like under the mast of this vessel or better yet a diagram or repairs undertaken at one time?
This is pretty serious issue and we are not sure how to proceed further with the seller unless he authorizes some invasive investigation!!
Thoughts??
F15E_WSO + 1
Deale Md, to Caribbean Oct 2012-Aug 2013
Boat Type Irwin 43 Mk III Center Cockpit--Sold it
Boat Yr, 1989
Boat Length 43'
F15EWSO is offline
post #2 of 4 Old 06-16-2012
souljour2000's Avatar
Re: Mast Step on an Irwin 43?
Thoughts??
I'm no expert but it literally "sounds' like you know what you got there...would make me wonder what else a P/O did sloppily... That could be a fairly severe repair regimen possibly as I am sure you know...would definitely affect asking price...You sound like you just need to get the seller to see what is there...and price accordingly...and that this is a pricepoint issue that you and your surveyor aren't just inventing out of thin air...
...And they say buying and selling a boat are the two best days..I disagree...
souljour2000 is offline
post #3 of 4 Old 06-16-2012
On the hard
CharlieCobra's Avatar
Not a cheap fix. We are replacing the mast step in a Tayana 37 at present. Doable but not cheap.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #4 of 4 Old 06-17-2012 Thread Starter
F15EWSO's Avatar
Yep Surveyor and Broker estimated $2k to pull and re-step the mast. Then the labor/materials is sketchy until we could get at the compromised area better. It would be nice if the box is separate from the stringer.
I added a photo to the OP at the top of the page
F15E_WSO + 1
Boat Yr, 1989
Boat Length 43'
F15EWSO is offline
Help with mast step pin(?) Lubrdink O'Day 6 12-18-2011 02:54 PM
Cal Mast Step micheck Cal 1 11-07-2010 07:16 AM
Is there a step by step for a stepping of the mast? Skipper Joe Gear & Maintenance 5 07-15-2009 08:45 PM
How often should I step my mast doons60 Gear & Maintenance 7 05-28-2009 01:58 PM
Advice on Irwin 28 mast step and spreader brackets msl Boat Review and Purchase Forum 0 04-08-2002 07:00 PM
