08-19-2012
Administrator
Re: Why would they do this?
Originally Posted by sea_hunter
It's a larboard, a traditional rig, hence the term starboard. All ships were designed this way, the port side was the docking side and did not have one. Healing over was undesirable in any event so it works just fine on ship carrying large heavy cargo.
With all due respect to my estemed colleague, this is mostly inaccruate. Starboard comes from Scandinavian via Old English and originally meant steering board. This referred to a steering oar which predated rudders as we know them. These evolved so that they were typically carried on the right side of the stern since the ergonomics worked best with (majority) right handed helmsmen. Because these steering oars were vulnerable to damage when docking, boats of that era put into docks with the left side towards the dock. That was the origin of that side being called the "port" side. The word 'Larboard' is synomymous with the word 'port' as used for a side of the boat and thatterm also came from Norse by way of Old English and meant 'loading side'.
Neither term has much to do with a leeboard. As the name implied, leeboards were generally carried on the lee side of the boat. Bigger boats with leeboards generally carried one on each side and the weather board on each tack was either raised or hinged to slide outward (colloquially referred to as 'broken wing') while the leeward board did all the work.
Leeboards were very uncommon in ships of any era or commercial vessels except in very specific regional typeforms, such as the Dutch Jacht shown.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Curmudgeon at Large- and rhinestone in the rough, sailing my Farr 11.6 on the Chesapeake Bay
