Whats the reason for the huge differences in displacements in similar sized boats? - Page 2 - SailNet Community
 4Likes
post #11 of 39 Old 08-27-2012
Moderator
Jeff_H's Avatar
Re: Whats the reason for the huge differences in displacements in similar sized boats
That's what I had in mind.
I like that, "design matrix" I'd like to use that. May I?
Thanks Jeff.
Bob,
I would be truely honored if you find anything useful to you in anything that I write. Please feel free to quote at will.
Zeehag,
I would respectfully suggest that you are missing a few words if you want your statements to be clearer and more useful. "Displacement is the weight of the water displaced by the hull of the boat and the weight of the water displaced by the hull at rest is equal to the weight of the boat on a scale."
See, isn't that clearer.....
Jeff_H is online now
post #12 of 39 Old 08-27-2012
Superior Sailor
Squidd's Avatar
So if the boat sinks, does it weigh more...??
A lb of lead sinks...displaces "X" amount of water...
A lb of Gold sinks....Displaces "Y" amount of water...
"X" and "Y" don't weigh the same....
So how can a lb of weight be the same as an lb of displaced water...???
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #13 of 39 Old 08-27-2012
Moderator
Jeff_H's Avatar
Displacement, as used in naval architecture, implies that the vessel floats. The weight of water that a vessel displaces while floating is equal to the weight of the vessel. Once it sinks, all bets are off.
post #14 of 39 Old 08-27-2012
grumpy old man
Squidd:
Google this:
Archimedes Principle
That will explain what is going on.
If you build a boat in your backyard and it weighs 10,000 lbs. it will sink into the water until it displaces a volume of water equal in weight to 10,000 lbs., 156.25 cu. ft. of salt water.
If you add 2,000 lbs. to your boat it will now weigh 12,000 lbs. and sink in the water until it displaces 187.5 cu. ft. of salt water.
Displacement measured in cubic feet times 64 ( salt water weighs 64 lbs. per cubic foot) will always tell you the weight of the boat.
Displacement is usually given in lbs. or tons .
Displacement and weight are the same thing.
Bob's Blog ....
bobperry is offline
post #15 of 39 Old 08-27-2012
Superior Sailor
Squidd's Avatar
OK, but as above Archemides put a one lb crown that was supposed to be "pure gold" in the water it should have displaced "X" amount of water...(but it had lead in it...)
So it only displaced "Y" amount of water....Be it cubic foot or tare weight...
Different densitys displace differing "displacements" even at the same weight...
So you should be able to have different displacement rated boats at the same weight and/or different weight boats with the same displacement...
(assuming they float)....but what if you hang/weigh them in a sling...?
"Captin Ron"
Squidd is offline
post #16 of 39 Old 08-27-2012
grumpy old man
Squidd:
To help you ponder: Maybe get your self a copy of Steve Killing's book YACHT DESIGN EXPLAINED and do a little reading. Study up on Archimedes Principle.
Bob's Blog ....
bobperry is offline
post #17 of 39 Old 08-27-2012
grumpy old man
Squidd:
Have it your way.
I made it all up just to mess with your head.
The weight of a boat hanging in a sling will be exactly the same as the weight of the water that boat displaces when it is launched.
I'll give you a tip. This is not a "theory". This is not up for debate. This is a fact of the physical universe and referred to as Archimedes Principle. You want to argue it? Call Archimedes.
SVAuspicious likes this.
Bob's Blog ....
bobperry is offline
post #18 of 39 Old 08-27-2012
Superior Sailor
Squidd's Avatar
I'm not arguing.... just having a hard time wraping my head around it...
I thought Archemides said "different densitys have different displacements at the same weight..." If that's not what he said, then I am mistaken and apologize for stressing you out...
On the other hand...If the world really is round....wouldn't all the boats slide off to one side or the other (unless they were perfectly balanced on top...?)
"Captin Ron"
Squidd is offline
post #19 of 39 Old 08-27-2012
grumpy old man
Squidd:
I'm not stressed out. I have done my best to explain this to you and that's all I can do. Now it's up to you. I think your understanding of Archimedes Principle is less than accurate.
Now it's off to my Tai Chi Chuan class where I will once again try not to tip over.
Bob's Blog ....
bobperry is offline
post #20 of 39 Old 08-27-2012
The most female moderator
Donna_F's Avatar
Dock
This image just made my night. Then I remembered how lazy I am and I stopped chuckling. Raising a glass to you.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
Catalina 22 vs. Macgregor 22 (or similar sized boat) tomg847 Boat Review and Purchase Forum 19 10-22-2016 06:20 PM
PSC actual Displacements / Drafts MC1 Pacific Seacraft 8 04-21-2010 09:14 PM
Looking for similar boats CrazyLeaf Boat Review and Purchase Forum 11 01-20-2010 12:25 PM
Whats with all the white boats? yellowwducky General Discussion (sailing related) 27 11-13-2008 05:41 PM
