Whats the reason for the huge differences in displacements in similar sized boats? - SailNet Community
 4Likes
post #1 of 39 Old 08-26-2012 Thread Starter
In my meandering through boat for sale ad online I came across this Atkins 35 Cutter with a displacement of 21 000 pounds 35'LOD and a 10'9" beam. I compared that to a Southern Cross 35 which displaces 17 700lbs and a Pearson 35 that displaces 13 000 lbs and has a 10' beam.
The Pearson and Atkin each have full keels so I expected their displacements to be similar, but they end up differing by 7000lbs compared to the Southern Cross and the Atkin which differ by only 3300lbs.
When compared further the LWL range from 25' on the Pearson to 28 on the Southern and 30 on the cross.
Would the extra fiberglass used to make the a hull with a longer LWL be enough to create this diffence in displacement? If not what other factors come in to play? I can imagine that thickness of the hull might be one culprit but what else?
Agri is offline
post #2 of 39 Old 08-26-2012
blt2ski's Avatar
Re: Whats the reason for the huge differences in displacements in similar sized boats
Accesories on the inside, ie stove and oven vs just a stone. How big the fuel, water, black and lp tanks are. type of interior wood, etc. Teak decks vs none. Engine size. Rig sizing.......just to name a few things.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #3 of 39 Old 08-26-2012
ebs001's Avatar
Ballast Atkins: 7500Lbs, Southern Cross 5750Lbs, Pearson, 5400Lbs
Amount of fiberglass ie it's thickness
ebs001 is offline
post #4 of 39 Old 08-27-2012
Superior Sailor
Squidd's Avatar
Isn't displacement the amount of water the hull shape "displaces" IE: cubic volume...
and has nothing to do with actual "weight" of the boat or construction...
So yeah, a lwl boat or a wider boat will "displace" significantly more volume...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #5 of 39 Old 08-27-2012
RichH's Avatar
The strategic differences are 'scantling difference' which determine the target service.
A simplified explanation of the engineering/design process that results in various and very different 'weights":
A boat designed for inshore (lake / river/ sheltered bay) service will typically have structure at 1.5 times the historical strength needed to insure survivability in that service; a coastal boat at 2 times the strength; an offshore / open ocean boat at 3 to 4 times the inbuilt strength.
All this determined from 'scantling history' or that which 'usually' ensures that under those 'normal' conditions found in those different venues that the boat doesnt break up and sink. Scantling history is the realm of marine insurers records.
RichH is offline
post #6 of 39 Old 08-27-2012
grumpy old man
Squidd:
Wrong!
And you are far from the first one to be confused on this.
Displacement has everything to do with weight.
Displacement is weight. A boat displaces it's own weight in water.
So displacement and weight are the same thing. You can use the two terms interchangeably when discussing boat hulls.
"What does it weigh?"
"What does it displace?"
Same question.
Differences in displacement in boats of similar DWL's is simpoly a matter of design approach a nd materials used. If you design a steel boat you will need displacement to float the steel. If you build a carbon fiber boat you will need far less displacement to flat the material. The same for a heavy, wooden hull like the Atkin. With thick planking and copious framing and backbone timbers the boat will require a lot of displacement to float the material and still end up with a suitable margin for ballast.
This is not an easy question to answer quickly. There are a lot of facets to it. This calls for one of Jeff's long design explanations.
Bob's Blog ....
bobperry is offline
post #7 of 39 Old 08-27-2012
Moderator
Jeff_H's Avatar
Here is one of my long design explanation. I wrote this for a diffent purpose so I apologize in advance that it is not precisely on topic, but it might shed some light on the original question.
Like most forms of design, yacht design is an iterative process. It actually works backward of the way that most folks might think it does. It starts with defining the purpose of the design in terms of how the boat is primarily intended to be used, (distance cruiser, coastal cruiser, live aboard, performance cruiser, trainer, racer, etc.), where it is likely to be used, how many crew are likely to use the boat at any given time, how and where it will be constructed (production vs. one off, sophisticated vs. simple construction oriented yard), quality vs. cost trade offs, owner preferences (both aesthetic and functional), and designer experience, judgment and preferences.
With a good designer, this matrix of factors will drive the rest of the rest of the design. For example, if this was a distance cruiser, with an anticipated crew of four, it would need to carry a lot more gear, and be more robust, than coastal cruiser for four, so it might be heavier and longer for that same crew number. If it was intended for the Pacific, it might be deeper than if intended for an East Coast of the US. If it is deeper it might have a smaller ballast ratio and be lighter. If it were a coastal cruiser, it might need to adapt to more frequent wind speed changes over a narrower range of wind speed and performance might be more important, than a distance offshore cruiser. It might therefore need more sail area, and therefore need a higher ballast ratio, and simpler easier to depower rig.
But when the designer and owner are all done with filling in that matrix, the designer will ideally come away with a carrying capacity that the boat will need. There is a relationship been the required carrying capacity and the overall weight (displacement) of the boat that varies with the intent of the boat. On distance cruisers, the structural safety margin needs to be greater, so the weight of the hull and structure needs to be greater relative to carrying capacity. This added weight means that the boat needs a larger engine to over come the drag of this added weight and with larger engines comes the need larger fuel tanks to have an equal range. And with all of the combined added structural, engine and fuel weight, the sail plan needs to be larger to achieve a reasonable performance. The added sail area means that the boat needs stability to over come the drag of this combined added weight, and this means adding more weight in the form of more ballast. The added structural stresses of this added ballast and added rigging loads, requires that the structure of the boat needs to be beefed up which adds still more weight. And collectively that weight starts the next iteration of the design weight cycle over again.
By comparison, on a race boat, the carrying capacity requirements can be and should be a smaller percentage as compared to the overall weight of the boat. A mix of high- tech construction, and slimmer safety margins, allow the weight of the hull and structure to be proportionately less as well. This allows a larger ballast ratio, which allows a larger sail plan relative to the overall weight of the boat.
Once the design weight of the boat is understood, then the intended accommodations need to be considered. To some extent, but not always, the accommodation plan is a major driver in the length of the boat. You would think that accommodations plan would directly drive beam width as well. But at least in my experience, beam is mostly driven indirectly by the length of the boat, and its intended purpose, while length is directly driven by accommodations. Of course there are some trade-offs between the two, and so you make tweak the beam a few inches here, or there to help an especially tight accommodations plan.
In and of itself, weight does nothing good for a boat. Weight does not make a boat stronger, it does not make it more stable, weight does not give a boat a more comfortable motion, and it does not make a boat more seakindly. Weight simply increases the stresses on the parts of a boat, makes it physically harder to sail, more expensive to build and maintain, and makes it slower.
But once designer has set the overall weight that is needed, and roughed out a length that is adequate to house the accommodations, the next step should be (within reason) to maximize the over all and waterline length. All other things being equal, if you compare two boats of equal weight, one being longer and the other being shorter, the longer boat will offer better motion comfort, be more seaworthy, be easier to handle, have an ability to carry more supplies, and be faster. In most cases, if the boats are of equal weight they will have a similar cost to buy, and maintain. But often personal prejudices or some unique aspect of the intended usage, will mitigate against maximizing the over all and waterline length.
When you talk about similar purpose boats, of similar lengths, but widely divergent displacements, what you are often seeing is the way that the owner/ builder and/or designer, understood the decision matrix, considered the ability of the builder to precisely control construction weights within a budget, and the preferences and prejudices of all involved.
Jeff_H is offline
post #8 of 39 Old 08-27-2012
grumpy old man
That's what I had in mind.
I like that, "design matrix" I'd like to use that. May I?
Thanks Jeff.
Bob's Blog ....
bobperry is offline
post #9 of 39 Old 08-27-2012
Superior Sailor
Squidd's Avatar
Squidd:
Wrong!
Same question..
I guess that darn Archimedes Guy was messing me up...
I thought he said two objects could "weigh" the same, but have different displacements...???
Which has nothing to do with Bouyancy....
"Captin Ron"
Squidd is offline
post #10 of 39 Old 08-27-2012
snake charmer, cat herder
zeehag's Avatar
displacement is the weight of the water displaced by the hull of the boat.
weight is the weight of the boat on a scale
formosa 41, cruising tropics
zeehag is offline
Catalina 22 vs. Macgregor 22 (or similar sized boat) tomg847 Boat Review and Purchase Forum 19 10-22-2016 06:20 PM
PSC actual Displacements / Drafts MC1 Pacific Seacraft 8 04-21-2010 09:14 PM
Looking for similar boats CrazyLeaf Boat Review and Purchase Forum 11 01-20-2010 12:25 PM
Whats with all the white boats? yellowwducky General Discussion (sailing related) 27 11-13-2008 05:41 PM
