Building bulkhead mounted table - SailNet Community
 2Likes
  • 1 Post By Faster
  • 1 Post By Faster
post #1 of 9 Old 11-19-2012 Thread Starter
I own an Ontario 32. It currently has a folding table in the center of the salon.
I'm trying to create more space in general but have some concerns with the new distribution of weight.
If I proceed to replace the folding table with a bulkhead table will it make that much difference?
The tables should weigh roughly the same but when not in use the new table will sit that much higher.
Any thoughts?
Thanks in advance
Glenn
barefoot is offline
post #2 of 9 Old 11-19-2012
Senior Slacker
SlowButSteady's Avatar
Re: Building bulkhead mounted table
The bulkhead mounted table on my Cal 2-27 folds up against a set of shelves; sort of a shallow table-sized cabinet). So It does provide some storage. But your concern about shifting the weight up is something I have also worried about. I avoid storing anything heavy (bottles of wine, cans of soup, et cetera) in it for just that reason. The only things I keep there are some board games, a couple of candle lanterns, my plotting do-dads, and some extra plastic drinking glasses.
Funny thing is, I've been toying with the idea of the opposite switch, going from the bulkhead mounted table to a folding table for other reasons. But, the weight distribution considerations might be an added bonus.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #3 of 9 Old 11-19-2012
I doubt that you'll notice anything significant on an Ontario 32..
I checked out the few in YW.. they all have fixed tables and heaters on the bulkhead where a table would have to go. Interestingly this one:
View Boat Photos - YachtWorld.com
has the table mounted considerably more off center to port than the other two. Maybe an alternate solution? Often there's a problem with a folding bulkhead table making it long enough, or stable enough if you make it multi-fold.
Faster is online now
post #4 of 9 Old 11-19-2012 Thread Starter
Thanks for your response Slow but Steady. Interesting, you are considering the opposite! I only recently purchased my boat and although I love it, I do see the benefit, like the Island Packet of having the extra space provided by having the bulkhead table.
This has been a design feature with the packet, I believe since inception. So there must be some distribution compensation.
barefoot is offline
post #5 of 9 Old 11-19-2012 Thread Starter
Thank you Faster.
My table is in exactly the same position. The heater is a solid fuel burning stove i would have to lose.( I would have to replace it of coarse )..Ontario can breed some cool weather from time to time. The existing table measures 40 inches more or less and there is just enough room to mount the same dimension to clear the cabin top.
Oh and thank you for mentioning the stability, I will build a prototype prior to installation to ensure it's not going to be a disappointment
barefoot is offline
post #6 of 9 Old 11-19-2012
Originally Posted by barefoot View Post
Thank you Faster.
Don't forget that that 40" is now going to start at the bulkhead rather than the existing location, and you'll lose the area taken up by the mast. If it's just the two of you most of the time that's probably not going to be an issue.. it may be if/when feeding a small crowd.
Also it's going to take a fancy hinge, I reckon, to get a full 40" long table to fold out at a comfortable sitting height.. do you really have 40" to the overhead from the existing table's plane?
Jghflash likes this.
post #7 of 9 Old 11-19-2012 Thread Starter
Actually with a level in hand i measured 41 1/8, so there is some room for error.
Having said that the mast did obstruct a clean line of design, so some thought will have to take place.
barefoot is offline
post #8 of 9 Old 11-19-2012
Oh.. that sounds good then, I'd have guessed less.
I suppose another plus of moving that 40" ten to twelve inches forward will give more move-around room aft of the table...
post #9 of 9 Old 11-19-2012 Thread Starter
Thanks Faster for all your insight!!
Sometimes my enthusiasm over rides sensibility,so I'll be sure to post my success or failure.
barefoot is offline
Deck mounted versus keel mounted masts VetMike Gear & Maintenance 35 02-17-2012 09:59 AM
building a bulkhead JESTER458 Gear & Maintenance 18 01-09-2011 11:58 AM
Inverted bulkhead mounted whale pump jumaggafanny Gear & Maintenance 3 03-24-2009 03:04 PM
Bulkhead table pictures needed for 37cc dweymer Irwin 2 08-14-2008 03:28 PM
Bulkhead mounted cabin heater. How hot? duffer1960 Gear & Maintenance 3 07-27-2003 07:32 AM
