Bob Perry's take on Wolfenzee's dream boat - Page 104 - SailNet Community
 248Likes
post #1031 of 1160 Old 07-07-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Re: Bob Perry's take on Wolfenzee's dream boat
Older fg boats vs new is a generalization. Any new boat built from scratch can be far better built than stock boats, but most new boats are far more poorly built than older FG boats, built when materials and labour were cheaper. Given the current cost of materials, such a boat would be extremely expensive. A freind many years ago, priced the cost of fibreglassing materials for a Bristol chanel cutter, Ater being given a quote of $12,000 for hull and decks, he watched me pull a 31ft hull, decks, cabin, wheelhouse, keels, rudder and skeg together in a couple of weeks,for $3500. Then, considering the cost of deck hardware for a fibreglass boat vs $1 a pound for the stainless to do it on a steel boat, he walked away from that project, and has been building steel boats ever since. The price gap is still the same, or greater.
No , I dont think you can avoid the "bad seamanship" of happening to run into Fukashima debris on a foggy night. Plastic under you doesn't automatically make you "luckier".
My boats are fast, go to windward well, and make good passage times. They have often outsailed fibreglass boats they were not supposed to outsail, including Beneteaus. Their strength has been proven beyond all reasonable doubt, over the last 32 years. There is no point in waterproof bulkheads, as there is little if any chance of punching a hole in 3/16th plate on a 36 footer. They have also proven that, with good initial preparation, planning and painting ,maintenance can be reduced to less that of a fibreglass boat undergoing hard , heavy full time use. Nothing breaks, pulls loose, or leaks in welded down gear, unlike with bolted down gear on fibreglass.
If my clients wanted a fibreglass boat, they would have bought a fibreglas boat . Many have, then decided to upgrade to steel. It is no secret to anyone sniffing around boats, that they are available for a fraction the cost of materials, in any size shape and a huge variety of designs. So why would anyone want to pay someone many times the cost of a boat, or decades of cruising funds, for mere drawings of a plastic boat, when so many real boats are availabe so cheap? All my clients know that. They just dont want to risk lives and that of their families, in a plastic boat, which couldn't survive a collision, unharmed, with a large piece of Fukashima debris, like a dock or wreck. Better to have your hull bounce off, unharmed, that to have it stowed in and end up relying on a bulkhead to keep you afloat, in mid ocean. After a long and thorough look at the boat market, they have concluded that the only way to get what they want, and in steel, is to build from scratch. Relatively good plastic boats are a dime a dozen. Designers in that field are currently the equivalent of people selling ice to Greenlanders. Good steel boats are rare around here. For anyone wanting one which doesn't take forever to build , one which uses the most modern methods, I have no competition. Most commercially built sailboats around here are 10 guage plate, right down to the bottom of the keel, painted one side only, zero paint inside, welded one side only, and that weld mostly ground off.
Most of my boats are 3/16th hull plate 1/8th decks, cabin, cockpit, and wheelhouse, 1/4 inch keel sides, half inch leading edges, and half inch bottomplate, welded both sides, cold galvanized wheelabraded and primed, 5 coats of epoxy tar on the outside, three coats of epoxy tar inside, sprayfoamed , and all outside corners trimed with stainless, reducing maintenance by over 80%
You just wont find a commercially built boat around here built to those standards. If anyone did , it would be priced far beyond the means of most cruisers. For a home builder it means a bit of extra time and expense, their own time. For a commercial builder, fully welded, a good paint job inside and out, stainless trim, extra steel thickness in important areas, etc, would mean bankrupcy, and no credit given to him by customers, who have no comprehension of the importance of such matters.
This metal boat had no watertight bulkheads, and the arrogant designers also declared it to be the safest boat every built. In fact one of them is purported to claim boldly that "She cannot be sunk, even GOD cannot sink her".
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
post #1032 of 1160 Old 07-07-2013
grumpy old man
Great Brent. That's good. 50 boats, that's something to be very proud of. Good for you.
They built 600 Islander 28's, 500 Freeport 36's and I'll stop there. Oh, no, wait, 600 Tayana 37's. I won't bore you with more numbers but I have lots of them.
101 Ct 54's. Sorry, just had to throw that one in. It was my very first grp design.
Probably not a good idea to play a numbers game with me. You admit you are challenged by numbers. But I do not think it's about numbers. It's about excellence in design and lasting value.
smackdaddy likes this.
Bob's Blog ....
bobperry is offline
post #1033 of 1160 Old 07-07-2013
Once known as Hartley18
Classic30's Avatar
Dock
Hey, Bob - c'mon, you said you were going to go easy on the guy!.
Seriously, don't sweat it. We know your skills and we know Brent's skills and you're both recognised yacht designers with (mostly) completely different approaches, ideas and opinions. There's nothing wrong with that.
How about we get back to the topic at hand... what was it again? Oh, that's right..
Brent Swain likes this.
Classic30 is offline
post #1034 of 1160 Old 07-07-2013
grumpy old man
Hart:
as an old Ashfield boy that's about as easy as I get.
I congratulate Brenton his success. As you said, we work in totally different areas. I see no reason for anyone to, I know the word, I just can't spell it, dimean? demean? damien? derneighn? ok put down my group of sailors.
If somone buys one of my boats and sails it every weekend with an occasional cruise for two weelk arond thr PNW. Who am I to tell him he is not a "real sailor"?
Bob's Blog ....
bobperry is offline
post #1035 of 1160 Old 07-08-2013
The Elephant
smackdaddy's Avatar
Bingo.
Game. Set. Match.
smackdaddy is online now
post #1036 of 1160 Old 07-08-2013
Heres another one I like, Its Aage Nielsen's Northern Crown
jak3b is offline
post #1037 of 1160 Old 07-08-2013
blt2ski's Avatar
I wonder if wolf would like THIS yacht! or any of us might like invictus. steel hull, composite superstructure! Not sure Brent has this ability to design a really nice steel boat like that one! not that I want a power boat........wife saw it off of Edmonds a few weeks back, described it to me, I thought "Invictus" Took a pic the next time I was in the Delta yard.......sent it to her............
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #1038 of 1160 Old 07-08-2013
Splashed
JomsViking's Avatar
Jeff_H and Bob did you do more of the interior, or did I miss that in all the excitement? I'd really like to see a discussion of that, as well as some of the good (and strange) ideas designers/builders/owners has come up with over the years, and not least Your take on this.
Looking forward to it!
/Joms
JomsViking is offline
post #1039 of 1160 Old 07-08-2013
Closet Powerboater
MedSailor's Avatar
My boats are fast, go to windward well, and make good passage times. They have often outsailed fibreglass boats they were not supposed to outsail, including Beneteaus. Their strength has been proven beyond all reasonable doubt, over the last 32 years. There is no point in waterproof bulkheads, as there is little if any chance of punching a hole in 3/16th plate on a 36 footer. ...
...They just dont want to risk lives and that of their families, in a plastic boat, which couldn't survive a collision, unharmed, with a large piece of Fukashima debris, like a dock or wreck. Better to have your hull bounce off, unharmed, that to have it stowed in and end up relying on a bulkhead to keep you afloat, in mid ocean.
While I don't doubt that your boats are strong, as that seems to be your main selling point, steel boats sink too when they hit stuff, even strong ones. It's not just the Titanic either (which curiously you criticize for not having watertight bulkheads and yet you say they are pointless in another post). I only know one person (who wasn't giving a lecture or selling a book) who has used a liferaft in anger. His steel yacht sunk out from under him 3 days outside of Hawaii after a collision with an unknown underwater object. Steel didn't protect him from a collision.
I also interviewed a boat owner (to do the Vic-Maui) of a GRP boat that hit a whale (they saw bloody chunky bits) and while it stove in part of the bow, it didn't hole the boat. It was GRP with some Kevlar included with the glass, a C&C I think.
Steel can be weak.
Steel can be strong.
GRP can be weak.
GRP can be strong.
A strong hull of GRP or steel is no guarantee of staying afloat after a collision. The ocean decides.
MedSailor
MedSailor is offline
post #1040 of 1160 Old 07-08-2013
grumpy old man
Joms:
Jeff did the interior in several iterations until he had it the way he wanted it. Then he did a deck plan. Not sure if he ever posted the deck plan. Maybe he should post it again. We can argue for a month over deck layouts.
Bob's Blog ....
bobperry is offline
Bob Perry's Tragic Loss smackdaddy General Discussion (sailing related) 16 07-09-2013 10:57 AM
What's your dream boat? dovetailnj General Discussion (sailing related) 58 07-08-2013 12:48 PM
What's your dream boat??? DavidB.UK General Discussion (sailing related) 4 06-22-2013 04:06 PM
Perry's new Sunday blog bobperry General Discussion (sailing related) 12 11-07-2011 06:05 PM
A boat dream! pjboots Boat Review and Purchase Forum 28 03-22-2007 03:10 PM
