Bob Perry's take on Wolfenzee's dream boat - Page 32 - SailNet Community
 248Likes
post #311 of 1160 Old 05-17-2013
Re: Bob Perry's take on Wolfenzee's dream boat
At the Shark Sipt Regatta off Cortes Island, the first full moon of August every year, we race boats spanning many decades, from ultra modern to 30s and before designs. For several years in a row it has been won by a boat a lot like Wolfe's boat, a 1958 design, on which the short keel hung rudder has been removed and replaced by a rudder much further aft, hung on a skeg. She beat the far more "Modern" boats, boat for boat, several years in a row. There is no handicap system or rating system in this race. The skipper has said "If someone removes the rudder from an Alberg 37 and hangs it aft on a skeg ,I will never catch him."
Brent Swain is offline
post #312 of 1160 Old 05-17-2013
The so called "Modernized" version, with wide, flat aft lines and super lean bows, is the kind of hull which goes down by the bow, and the stern lifts up, when she heels, the centre of buoyancy moving well aft as she heels. This is the kind of hull shape which gets extremely hard to control downwind, a boat with zero directional stability. My first boat was that kind of bad hull balance. After sailing it across the Pacific, I never want to sail that kind of boat again, and certainly wouldn't want to impose it on anyone else.
Twin rudders may make it slightly more controlable , but it would still much rather broach than sail in a straight line, and I think using a balanced hull shape is a better and simpler solution.
post #313 of 1160 Old 05-17-2013 Thread Starter
Moderator
Jeff_H's Avatar
Brent,
You really like to say that don't you. As I have shown you in other threads on this topic, properly designed that just is not true. It has not been true with good designers for decades now. It is completely possible to design a boat with a fine bow and a powerful stern that does not change trim with heel. You really need to spend more time around modern boats.
Jeff_H is offline
post #314 of 1160 Old 05-17-2013
grumpy old man
I believe there is an alternative universe where Alberg 35's with skeg hung rudders will be considered high performance boats and be faster than the modern designs of today.
Right.
Bob's Blog ....
bobperry is offline
post #315 of 1160 Old 05-17-2013
Senior Moment Member
SloopJonB's Avatar
It's in Campbell River Bob - I'm surprised you don't know about it, living so close.
SloopJonB is offline
post #316 of 1160 Old 05-17-2013
grumpy old man
JonB:
I am working hard right here on Port Susan trying to create my own alternative universe.
Hot rod Alberg 35:
I hate to kill a fairy tale but here goes.
If you removed the rudder from the A35 and moved it aft on a skeg you would probably be moving the rudder about 3' considering how long the chord of the A35 keel is as designed. The rudder would be tucked up under the counter so it would have to be a deep rudder. Now add a skeg and the net result will be a gain in wetted surface. So light air speed will suffer. The only possible benefit of moving the rudder would be to possibly improve helm feel, steering and most certainly handling under power. There is nothing about simply moving the rudder aft and adding a skeg that would improve the speed of an A35.
Bob's Blog ....
bobperry is offline
post #317 of 1160 Old 05-17-2013
You mean boats like these?
We can see how difficult is to sail them and how little directional stability they have
post #318 of 1160 Old 05-17-2013
outbound's Avatar
Bob/Jeff- got it. sorry for my clumsy use of language. Didn't think drag would impact on comfort but thought "polar moment" would have a negative impact on speed. Pesonally found if the period between waves was just right ( or wrong) the tayana made me ( and crew unhappy) far reaching. Thing would get a corkscrew motion that was unpleasant. Other than that was wicked comfy as we say in N.E. even beating.
s/v Hippocampus
Outbound 46
outbound is offline
post #319 of 1160 Old 05-17-2013
grumpy old man
Out:
You are totally correect. It goes for almost any boat that some combo of wave and wnd on a broad reach will make it behave less than gracefully. Old Ed Monk Sr. said that for Puget Sound a DWL of 34' was perfect for motion in our chop. The Valiant 40 has a DWL of 34'. Coincidence?
With a high polar moment of inertia the boat is bucking around buit equally as bad is the fact that the rig is bucking around also and given the arm of the rig it's bouncing and bcking around a lot. This makes consistant sail trim next to impossible and speed suffers.
Hard to sail efficiently when the angle of attack is swing through 30 degrees or more in the vertical plane.
Bob's Blog ....
bobperry is offline
post #320 of 1160 Old 05-17-2013
blt2ski's Avatar
Interesting thought on the DWL for here in puget sound. I know my 25'wl is not always that fun! Especially a few weeks ago, going against a 15-20knot wind out of the north, with 2-3 knots behind me! Buried the nose more than once. Along with the flattish section in front of the keel hitting at times.......anyway.......
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Bob Perry's Tragic Loss smackdaddy General Discussion (sailing related) 16 07-09-2013 10:57 AM
What's your dream boat? dovetailnj General Discussion (sailing related) 58 07-08-2013 12:48 PM
What's your dream boat??? DavidB.UK General Discussion (sailing related) 4 06-22-2013 04:06 PM
Perry's new Sunday blog bobperry General Discussion (sailing related) 12 11-07-2011 06:05 PM
A boat dream! pjboots Boat Review and Purchase Forum 28 03-22-2007 03:10 PM
