Bob Perry's take on Wolfenzee's dream boat - Page 79 - SailNet Community
 248Likes
post #781 of 1160 Old 06-25-2013
wolfenzee's Avatar
Location: S/V Waltzing Matilda, Port Ludlow, WA (NW Puget Sound)
Re: Bob Perry's take on Wolfenzee's dream boat
I remember Scanmar yachts, a very attractive, well built and fast FG Swedish boat, were built to be able to hit a submerged rock at 5kt with not structural damage....one of the building requirements. The Scanmar 40 which sold for $130,000 new in 1990 sells for $100,000 now (if you can find one, there were only 20 built). Not my "style" of boat, but is I were to go with a glass boat and had the $, I'd seek one out.
wolfenzee is offline
post #782 of 1160 Old 06-25-2013
Once known as Hartley18
Classic30's Avatar
Dock
(nice new avatar C)
Thanks, TD - it's taken from a video of the old girl roaring along at full speed in the last CYAA Winter Series race a couple of weeks back. Only missed 1st place by 13 seconds!..
Here's the (shaky amateur) vid:
Great fun. Wish you were there!
Classic30 is offline
post #783 of 1160 Old 06-25-2013
CYAA Winter Race 3 - June 2 2013 - YouTube
Oh hell yeah!!
That looks like a great day Hart! Well done, man!
smackdaddy is offline
post #784 of 1160 Old 06-26-2013
Beautiful!.Is that boat at 2:48 with sail # R 604 an Alan Payne design?
jak3b is offline
post #785 of 1160 Old 06-26-2013
Originally Posted by outbound View Post
Jak- can't recall the number of times I heard of or seen a motor boat rip off its strut and prop(s) blasting across Brown's Bank. Keep your dad out of Plymouth (GRIN).
Yup, The joys of sailing there.Shoals,rocks and lobster pots.Out here in SF Bay there are only a couple of ledges to worry about.We have lots of wind,fog,strong currents. a steady stream of BFS's(big fookin ships!).Heres a vid of my favorite boat, an Avance 36, somewhere in the Baltic, I think,with a nice traditional sound track;
https://www.youtube.com/watch?v=QmOQ6yKuqtU
jak3b is offline
post #786 of 1160 Old 06-26-2013
Classic30's Avatar
Dock
Yep, that day was fun. A bit bumpy, but blowing never less than 15kts.. good fun.
Nope, it's Fair Winds - a full-blooded Phillip Rhodes..
post #787 of 1160 Old 06-26-2013
Ah ok, Thank you!
jak3b is offline
post #788 of 1160 Old 06-26-2013
Classic30's Avatar
Dock
Ah ok, Thank you!
I'm sure Alan Payne's family would be most pleased to hear that someone mistook a design from one of America's finest for one off Alan's humble drawing board..
post #789 of 1160 Old 06-26-2013
I think he drew some beautiful boats.From What I have read he would be Australias Phil Rhodes
jak3b is offline
post #790 of 1160 Old 06-26-2013 Thread Starter
Moderator
Jeff_H's Avatar
I notice no-one's mentioned concrete. As a kid seeing a world-traveller's properly-built concrete hull come to grief on a reef in north queensland wasn't a pleasant experience either.
Actually that was one of the main reasons my parents had an Adams-designed steel-hulled 52-footer built not long after..
Hartley,
I want to start with an apologize to you and say that I am not ignoring you. I know that I owe you more information on the work that I am doing on the trade-off between sail area and sail power. Its hard to explain in few words and I have not been comfortable with my first draft explanation.
Regarding ferrocement, the panel weight for a typical under 40 foot long Ferrocement boat is 5 to 7.5 lbs (depending on percentage of reinforcing used) roughly the same weight as a steel boat plated in 3/16" to 1/4" plate. Depending on the actual design of the ferrocement materials involved, for an equal weight that typically results in the F.C.having roughly 1.25 times the bending strength, 3 times the stiffness but only between .8 and .9 times the impact resistance of steel.
I also want to touch on Outbound's point about steel having non-directional strength distribution and also his point on ductility. This is an important point when used on boats with a large panel dimensions such as the Origami designs or a boat with minimal internal framing.
Non-directional materials offer little or no advantage on conventionally constructed boats, where normal load paths are well understood and even highly focused point loads such as an impact or a prolonged grounding on a sharp edge, distribute across the shortest dimension of the panel and therefore have an orientation.
Ductility is a similar issue. Its true that low strength steels will deform more than almost any other material without breeching. This is less true for the higher strength steels (often used in boat building) which trade lower ductility for higher strength.
But to me, ductility has almost no benefit. To me what is critical is at what load the material will rupture in an impact situation and when compared on a pound by pound basis, both glass and wood have higher impact resistances.
But it is also important to reitterate that not all ferrocement or fiberglass boats are created equally. For example, the fiberglass panel I used in my example above was specifically designed for impact and bending strength. The resin used is the same vinylester popularized in crash and military helmets. The core was specifically chosen for its energy absorbing ability. The laminate used almost no non-directional materials. In the Naval Academy studies, it was also the least expensive of the panels tested. That laminate is acceptable when comparing custom built boats designed for low cost and impact resistance as prime objectives. But it needs to be said that there are almost no production boats that actually employ that resin and laminate schedule.
I would also like to repeat a comment that I made in another discussion on this topic. Anyone who has ever held a piece of 1/4 steel plate in their hand could not help but be impressed with how seemingly indestructible this material would appear to be. And anyone who has ever worked on a poorly built fiberglass boat, will also come away with an intuitive sense of the potential vulnerability of fiberglass.
But my post is intended to clarify the reality of situation, which is that when compared on a pound for pound basis, using accepted engineering data, steel just does not do all that well against properly designed and properly build composite or cold molded boats. While I gladly admit that I strongly prefer lighter weight boats and better sailing boats for my own use than can typically produced in steel, that still does not change the realities of the materials in question.
Respectfully,
Classic30 likes this.
Jeff_H is offline
Bob Perry's Tragic Loss smackdaddy General Discussion (sailing related) 16 07-09-2013 10:57 AM
What's your dream boat? dovetailnj General Discussion (sailing related) 58 07-08-2013 12:48 PM
What's your dream boat??? DavidB.UK General Discussion (sailing related) 4 06-22-2013 04:06 PM
Perry's new Sunday blog bobperry General Discussion (sailing related) 12 11-07-2011 06:05 PM
A boat dream! pjboots Boat Review and Purchase Forum 28 03-22-2007 03:10 PM
