Bob Perry's take on Wolfenzee's dream boat - Page 90 - SailNet Community
 248Likes
post #891 of 1160 Old 07-01-2013
blt2ski's Avatar
Re: Bob Perry's take on Wolfenzee's dream boat
Originally Posted by Jeff_H View Post
Did someone say that for our next trick we are drawing a halibut schooner built with modern materials?
Oh shista, lord help us, along with a few other words we can not say/type on this forum! I think I could get pics of nekid women to last longer!
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #892 of 1160 Old 07-01-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
yes please ... have at it lads.
One of my favourite designs was the 48' motor sailor that BP designed and was sadly never built (client Dopyera). As a cruising liveaboard for Tasmania, New Zealand, Scandinavia or the PNW it just seemed pretty close to ideal. The redesign of the Halibut Schooner sounds like a wonderful development of that project.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #893 of 1160 Old 07-01-2013
jak3b is offline
post #894 of 1160 Old 07-01-2013
grumpy old man
Maybe I already did that. I am meeting with this client, Emil Doperya, in two weeks to decide where we go next. Emil's Dad and Uncle invented the Dobro. Emil has one circumnavigation under his belt. He likes my work.
Jak:
That footage of the old boats brings this old Ballard kid to tears.
But those fragile old wooden boats with 2.5" planking won't last.
Many thanks for posting that.
Bob's Blog ....
bobperry is offline
post #895 of 1160 Old 07-01-2013
Jak:
Your very welcome.Wow, the Doperya family!.very cool clients Bob.I love the sound of the dobros, also the old National Steels.I saw that youtube a couple weeks ago.I like fragile old work boats.The Stonington draggers were cool old boats to.Strictly for the summer inshore fisherman though.
jak3b is offline
post #896 of 1160 Old 07-01-2013
Brent,
First of all, when I mentioned "low cost, speed of construction, and impact resistance" as primary design criteria, that was my attempt at paraphrasing my understanding of what seemed to be your consistent primary concerns in all of these discussions over the years. My primary concerns would include exceptional sailing ability, ease of handling, seaworthiness, seakindliness, and appealing aesthetics, and that would preclude steel for boats of a size that would appeal to me.
But that aside, as you should probably recall from our earlier detailed discussion on this, and the spreadsheet and reference notes that I provided at that time. In that earlier exchange, I had taken one of your Origami designs and had calculated the sheet sizes and weight of steel, welding rod, etc. involved in building it, and gotten a local, delivered price for those materials.
I did the same for the plywood, kevlar, glass and resin to build the same boat stitch and glue. They were close in price with the plywood composite construction being slightly less expensive.
On that spreadsheet, I had also gone to a welding manual and showed the rate of speed that an average professional welder could cut and weld the hull of that boat in steel and had put together a similar estimate of number of hours for the plywood composite boat built to a similar simple level of finish.
As you may recall from that analysis, you were right that you could 'pull together a steel hull faster. But when you factored in the time to prep and paint the steel boat, and that the wood composite version had more of its interior in place, the difference in time was negligible, and if there were layouts for cutting out the interior components, it looked like the wood composite version could be ready to go cruising slightly faster than the steel version.
And, yes, if constructed with kevlar and plywood skin of an equal weight to your steel hull skin, I would expect the composite hull to stand up equally well to being beaten by a sledge hammer for as long as you would like.
Brent:
You really need to read more carefully, what was actually said was a wood/ kevlar composite hull would be stronger than a steel hull of an equal weight. But the military does not need me to tell them about composites. The latest US Navy front line ships are being constructed using primarily composite construction. They are doing this as a cost savings in terms of life cost, strength to weight, performance and the ability to protect the crew in battle.
Naval Composite Ship Program Moves Ahead
As to gun barrels, they are made from steel for material behavior reasons that has nothing to do strength concerns. Steel conducts heat much more effectively than composites. In the case of a gun barrel, one of the prime concerns is being able to keep it cool and there steel is more effective than composites.
On the other hand, on a cruising boat, the ability of a composite hull to reduce heat flow through the skin is a good thing making it more comfortable below than a steel boat, assuming equal weight and equal external insulation levels.
Respectfully,
The suggestion that any wooden boat can be as strong as steel is ludicrous. They survive no more than minuites on a coral reef in surf.Steel hulls sometimes last decades. The Yankee went ashore in Rarotonga in 64. In 73 I walked around her, hull and decks still intact. How many plywood boats last more than a few minutes in that situation, fibreglass boats not much longer.
How many hurricane seasons in open ocean on a coral reef was that?
Exceptional sailing abiliity in the average, heavily loaded cruiser, with all the owners worldly possesions aboard is almost non existent in the cruisers plying the worlds oceans ,nor do any realistic cruisers so naively expect it.Middle of fleet is the best they expect, and that does the job just fine. Those who spend megabucks for that extra quarter of a knot are still at home paying for it, while the slowpokes are out cruising, early and long.
Ease of handling, seaworthiness, seakindliness, of my boats have been proven over many decades and many ocean crossings to be one of the better proven ocean cruisers, certainly far better proven that one freshly off the drawing board. If they hadn't ebeen they wouldnt continue to be so polular and so much in demand , and no one after a pacific circumnavigation, would be building a second one, let alone a third. As for aesthetics, the photos Smackdady posted in this thread should clear that up.
We get all our steel wheelabraded and primed with cold galvanizing primer , eliminating the need for sandblasting , making prep minimal and easy.Did your cost estimates include sandblasting, an expense we dont have?
The 1 1/2 inch of spray foam we put on our interioirs is a far better insulator that plywood and epoxy. I remember living under the plywood deck on my first boat, seeing a layer of ice above my head ,with the wood stove roaring. Living under a foamed steel deck is warm and dry, as warm and dry as any boat can get, without the inevitable deck leaks from bolted down fittings, instead of the permanently waterproof welded down fittings, which cost me a dollar a pound. Someone speculating on the difference can be extremely naive, without having lived under both options thru a BC winter; definitley not a good source of advice on the matter.
The demand for my boats is also strong for their reputation for extreme comfort in winter, both underway and at anchor. The difference between plywood and steel, after an inch and a half of foam, is negligible.
Were your cost comparisons for a plywood boat of the same weight as the steel boat, or the same impact resistance, a plywood hull nearly 12 inches thick ?I dont think your thin coat of kevlar would be the equivalent stopping power of 3/16th plate.
The claim that it is only heat which makes wooden gun barrels impractical is ludicrous. Hunting rifle barrels dont heat up noticably. They are stamped 13 tons to 19 tons per square inch. How would your wooden barrel stand up to that kind of pressure.
They thought the use of aluminium for warships was a good idea til the Faulklands war, when they found they burn like cardboard. Looks like the military will have to re-learn that lesson of history with composites. I think that is the oxy moron called "Military intelligence". No surpirse considering it took until ww2 for them to change from Roman strategy to a strategy which caught up to their firearms technology.
Getting dark time to go. Swimin tomorow, while the guys paying for their High teck boats go back to work. Water was 71 degrees F alongside today, warmer tomorow . Will jump overboard several times a day. Do I wish I was working; to pay for a boat which goes a quarter knot faster? Not a chance!
Brent Swain is offline
post #897 of 1160 Old 07-01-2013
grumpy old man
Go to bed Brent. Your typing, general thought process and attempts at sentance structure tells me you have had a long day again. We are talking about important things here. Your owners go on the rocks at an alarming rate. That is very strange. And yet you brag about their stupidity and lack of navigation skills. Weird.
My apology Brent. It's Canada Day, you have every right to be celebrating. Happy Canada Day to you. Nighty night.
Jak:
Emil has a collection of some Dobros built by his Dad and Uncle that would make you drool. I keep dreaming that he will leave them with me to store. He's a good pal. He has house sat for us twice and I trust him and with my dogs. Which if you know me at all says a lot.
Bob's Blog ....
bobperry is offline
post #898 of 1160 Old 07-02-2013
The dog I understand. I was raised by a german shepard bitch. The dobros well I have an affinity for 12ve strings. That ketch has an interesting flavor. The masts look too far apart. And with enough sail to move it would it be easy to knock down?
desert rat is offline
post #899 of 1160 Old 07-02-2013
Brent:
Check out this list:
OIlin Stephens
Phil Rhodes
John Alden
German Frers
Bruce Farr
Bill Lapworth
Gary Mull
I coud go on but I'll stop there.
Then just for the hell of it lets ad those two young whippersnappers
Chuck Paine
Bob Perry
Walk down any dock in any marina in north America and mention those names to any sailor and they wil have heard those names and most probably have some knowledge of each designer's work.
All of those designers have one thing in common. They are learned their craft working in what you call an "urban office". They did it the old fashioned way, working for older men who were experts at the craft. I suppose any of them could have taken off and gone cruising but they didn't. They wanted to be yacht designers and they knew the path to get to a level where they could open their own offices and it wasn't out cruising. Some technical education in yacht design was and is required. Those guys on my list are pretty well known today. Some are quite famous.
Now walk down a dock and mention Brent Swain and I am pretty darn sure you will just get a blank stare back.
" Who?"
Sorry but this is the real world. You wanted "real"
Maybe you should have taken the time to get some professional training as a yacht designer. You might be comfortable with numbers now and not stumble over the technical side of yacht design saying stupid things. Numbers are our common vocabulary when discussing many of the design features of any boat A good designer has be happy and confident working with the numbers. If you are uicomfortable with numbers you are really going to struiggle with any analysis of stability. I did my first stability study by hand. Maybe Brent, you would have had some training in how to design a pleasant looking deck house.
But you did it your way and it shows in your handful of boats. I did it my way and I think it shows in my body of work and numerous very succesful designs. I followed the path set down by a lot of the men I looked up to in this field from the time I was a boy. Really, I did it "their way" and I am grateful to the men who hired me and mentored me as I worked to learn the craft. If I had to do it over again I would do it exactly the same way. It has worked quite well for me.
They all have one thing in common. They alll leave the helmsman in an open cockpit as the only steeriing option; bad seamanship, of the most naive and pretentious kind . Another thing they have in common.Benteau would be extremy wise to hire them for their aesthetic genius, to eliminate the extreme uglines of Beneteaus ( and other similar boats, like Hunters, Jeneaus, etc
post #900 of 1160 Old 07-02-2013
Senior Moment Member
SloopJonB's Avatar
I'm pretty sure the Spitfire was a very early succesful use of what we call "cold molding" now. But it was a flimsy little plane that didn't work very well.
The Spit was metal - the Mossie was wood.
SloopJonB is offline
Bob Perry's Tragic Loss smackdaddy General Discussion (sailing related) 16 07-09-2013 10:57 AM
What's your dream boat? dovetailnj General Discussion (sailing related) 58 07-08-2013 12:48 PM
What's your dream boat??? DavidB.UK General Discussion (sailing related) 4 06-22-2013 04:06 PM
Perry's new Sunday blog bobperry General Discussion (sailing related) 12 11-07-2011 06:05 PM
A boat dream! pjboots Boat Review and Purchase Forum 28 03-22-2007 03:10 PM
