Lewmar portholes leaking - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
 2Likes
  • 1 Post By TakeFive
  • 1 Post By hellosailor
post #1 of 7 Old 03-21-2014 Thread Starter
After 16year, rain water is coming in through my lewmar portholes of my moody S38. I am not certain if i need to change the rubber seal, or dismantling the port holes, chalking them and refitting them. Anyone has any suggestion please.
Paul Victoria.
Paul Chetcuti is offline
post #2 of 7 Old 03-21-2014
night0wl's Avatar
Re: Lewmar portholes leaking
Take some advice from my hatch process...
In my boat, it actually ended up being the gasket material under the attachment for the hatch hinge to the glass on the hatch itself. THis ended being a big drama as the gasket is not sold by itself...you have to order a whole new friction hinge. The reordered friction hinge assembly ($84!!) ended up having gasket material that didn't plug my gap. So, I ended up going to home depot and getting weather stripping material of the appropriate thickness and using an x-acto knife to cut it to shape...$8 including the cost of the x-acto knife. That and a few spare parts for a lewmar friction hinge....grrrr
BTW, did I mention my *EXTREME* dislike for all things Lewmar customer service related? They're awful. If it is gaskets around the perimeter of the hatch/port...I feel sorry for you. Each gasket is like $30-$50.
S/V Jendai
Beneteau 343
night0wl is offline
post #3 of 7 Old 03-21-2014
tdw
Super Fuzzy Moderator
tdw's Avatar
Sorry to interupt but the friction hinges on those ports ..... is there any way to adjust them ? Some of ours are getting a bit loose.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #4 of 7 Old 03-21-2014
night0wl's Avatar
Do you mean your ports aren't staying open anymore? IF so, there is an allen bolt/hex bolt that i just tightened up. I'm sure eventually this will wear out and I'll have to put rubber spacers or rubber washers to keep things "tight"...but for now, I just crank down on the allen bolt.
S/V Jendai
Beneteau 343
night0wl is offline
post #5 of 7 Old 03-21-2014
tdw
tdw's Avatar
Thanks for the reply and yes that is what I was talking about. I attacked one of them but as I wasn't sure if those hex bolts were there for that purpose i thought I'd ask rather than have one of the damn things shear off.
― Terry Pratchett.
tdw is offline
post #6 of 7 Old 03-21-2014
TakeFive's Avatar
Paul Victoria.
Maybe this is obvious, but check the rubber seals for organic matter. I keep mine clean, but I can't tell you how many boats I found when shopping in rainy weather several years ago that had leaks coming through, and I opened and found all sorts of organic decayed matter causing the leaks. Cleaning them eliminated the leaks. (I should have charged the owners for the service.)
Multihullgirl likes this.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
The Following User Says Thank You to TakeFive For This Useful Post:
Multihullgirl (03-22-2014)
post #7 of 7 Old 03-22-2014
Paul, you need to confirm where the leak is first. If the seals have gone bad and can't be replaced, try an auto body supply or RV supply to find a similar rubber, they often have quite a variety, more than the hardware stores.
My car trained me: I use ArmorAll regularly on all seals, and the rubber stays way more pliable and doesn't age or crack the way untreated rubber does.
tdw likes this.
hellosailor is offline
leaking Lewmar opening port sails7plj Announcements and Suggestions Box 0 03-07-2010 12:13 PM
Leaking older Lewmar hatch imiloa Gear & Maintenance 0 08-20-2009 11:50 AM
9.6 Portholes? timweiler Columbia & Coronado 1 06-03-2008 10:35 AM
Refurbishing portholes smallyachts Gear & Maintenance 1 04-12-2007 02:27 PM
Leaking portholes dsprygada Gear & Maintenance 1 01-31-2005 06:31 PM
