Which Boat to Buy - Page 2 - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #11 of 22 Old 12-04-2009
It all depends on the money you have. You could choose anything from a small boat, a speed boat etc to a luxury yacht.
But like mitiempo said, the Alberg 37 would be a good choice.
Jasonparker700 is offline
post #12 of 22 Old 12-09-2009 Thread Starter
Thanks for the suggestions. My list has changed a bit and I've found two boats that I'm trying to choose between. An Alberg 35 and a Tartan 34. I really like the accommodations and overall looks of the Tartan but the swing keel makes me a bit nervous. It is very nice to have <4' draft with the keel up where the Alberg draws 5 & 1/2. It has the original A4 which to me is a major negative. The Alberg has a newer Universal M25XP diesel and is in similar condition otherwise. Asking prices are close. My questions is, all things equal (other than the engine), which of the two would be the best "go anywhere, do anything" boat? I'm not interested in formulas, just opinion and experience.
brob76 is offline
post #13 of 22 Old 12-09-2009
mitiempo's Avatar
Of the two I like the Alberg. Pretty boat.
Brian
mitiempo is offline
post #14 of 22 Old 12-11-2009 Thread Starter
I ended up buying the Alberg. Offered 8K and they took it. It's a bit of a mess. I'm going to spend quite a bit time cleaning it up but the hull and deck are in great shape as is the engine. One thing it has that I'm unfamiliar with is in-mast main sail furling/reefing. Does anyone have any experience with these types of furlers? Are they problematic?
brob76 is offline
post #15 of 22 Old 12-11-2009
mitiempo's Avatar
That would mean that the mast is much newer than the boat. While they have their detractors they apparently work quite well. Those that have them like them usually. Almost all Beneteau and Catalina that are larger have them as standard now. Congratulations. Now the work starts.
Brian
mitiempo is offline
post #16 of 22 Old 12-11-2009 Thread Starter
Thanks! Hopefully going to get the basics done this winter (bottom, sails and rigging) and get 'er in the water by spring. I'm wondering how difficult it would be, or if it's possible, to convert a furling mast to standard sailtrack. Never had an issue with single line slab reefing.
brob76 is offline
post #17 of 22 Old 12-11-2009
mitiempo's Avatar
I prefer 2 line slab (easier on the sail than single and easier to tension the luff) and that is what I have now, but with inmast as long as it's there you may as well use it. I would guess you would have to change the mast maybe to convert, but I'm not sure. One downfall is that you lose the roach as the sail is usually without battens. Good luck.
Brian
mitiempo is offline
post #18 of 22 Old 12-11-2009
Converting an in mast furler to standard main is probably possible but not practical I don't think.. the section is different, heavier, the slot isn't always centered, etc... I think Brian's right that you'd be better off to replace the mast altogether.. an expensive proposition.
I'd agree you should see whether you like it/hate it before deciding what to do about it.
Faster is offline
post #19 of 22 Old 12-11-2009 Thread Starter
Thanks for the advice. I'll try it out and see how I like it. Just that the idea of IM roller furling concerns me. Worried that it may jam at an inopportune moment. Slides rarely let you down.
brob76 is offline
post #20 of 22 Old 12-11-2009
In general I agree with you and would prefer not to have it... but I've never had one either so may be biased based on hearsay..... Obviously these rigs are much improved of late - your success may well depend on how new/recent a version this one is.
Faster is offline
Trailering? Pick a Boat Bruce Caldwell Cruising Articles 0 07-22-2004 08:00 PM
Boat Swapping Mark Matthews Cruising Articles 0 07-15-2004 08:00 PM
Naming and Renaming Your Boat Sue & Larry Buying a Boat Articles 0 12-15-2003 07:00 PM
Refitting an Older Boat Sue & Larry Gear and Maintenance Articles 0 12-16-2000 07:00 PM
