Replacing carpet with cedar - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 8 Old 02-14-2010 Thread Starter
I was thinking of replacing the carpet that lines the v birth with cedar. Does anybody have any suggestions on the best way to adhere it to the haul? Should I use sleepers or directly to fiber glass haul? Has anybody use cedar in this application before or any other type of wood? Thanks.
LANCE37HUNTER is offline
post #2 of 8 Old 02-14-2010
davidpm's Avatar
I have not done it myself in 30 plus years but a recent article showed someone who glued on sleeper's, they notched them to get them to bend. Then filled the spaces with insulation and screwed on 1/4" by about 2.5" slats.
It's a lot of work but would look nice. Insulation would only be useful if you needed it for heat or cold control.
davidpm is offline
post #3 of 8 Old 02-16-2010
Cedar in vberth
did this on our previous boat, an Islander 29....expoxied scarfed strips to the hull and then put insulation between (helped the sweating at least). Used some 1x4's cut to different lengths to wedge them strips to the hull while the expoxy set. Cedar strips were then glued with construction adhesive and electric nail gun and short tacks to secure the strips in. Cedar was some you get at Lowes for closets.....maybe 1/4 inch. Done 4 or 5 years ago and still there. Some varnish over and looks good.
Thisisus
Islander 32
Mobile AL
byrd151 is offline
post #4 of 8 Old 02-18-2010 Thread Starter
Thanks for the input it is really helpfull
post #5 of 8 Old 05-19-2010
blueranger's Avatar
This sounds like something I'd like to do to the v-berth on my boat; give it a little warmth. But what the heck is a sleeper?
Thanks,
Mike
blueranger is offline
post #6 of 8 Old 05-22-2010
davidpm's Avatar
Think of what the ribs in a wood boat would look like. Only much smaller. Maybe only 1/4 to 1/2" in thick and about 1/2" wide. You pick the thickness based on the thickness of the insulation you put in between them. Put them about 12 to 18" apart depending on the curve. Epoxy them to the hull. You can notch them so they will make the curve.
They are just someting to put the slats on (nail, screw glue). (cealing in wooden boat talk).
davidpm is offline
post #7 of 8 Old 06-21-2010
waterant's Avatar
Hi,
Have you consider this:
PlasTEAK
or similar? I'm replacing my floor on Bayfield 32 and it looks and feels excellent.
Here is my work in progress:
Carpet alternative
Still need to put double side tape under it and trim on the edges.
Hope this helps.
Ant
Small boats - Big fun (Canada)
waterant is offline
post #8 of 8 Old 06-28-2010
Love the Plasteak! just so expensive ... I'm thinking about trying Home Depots snap together wood flooring, no holly contrasts but some claim good water "resistance". I mean if the cabin floor gets wet then i have more problems then $50 worth of fake wood....
justjon is offline
Carpet in the cabin wintermute11 Gear & Maintenance 14 01-16-2009 11:01 AM
Cabin Carpet rcibul Gear & Maintenance 4 08-15-2006 09:55 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 07:00 PM
Replacing the Diesel Tank Sue & Larry Gear and Maintenance Articles 0 09-18-2002 08:00 PM
Replacing Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-22-2000 07:00 PM
