drilling and cutting fiberglass - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 9 Old 10-06-2010 Thread Starter
I would like to mount some oarlock holders on my sail boat. The boat is from the 70ies and is fiberglass. Really worried about trying to drill or cut the material. Worried that it will just splinter. Any thoughts on how to do this?
It would be cool if someone made clamp on oarlocks but I haven't found any online.
caver504 is offline
post #2 of 9 Old 10-06-2010
One of None
deniseO30's Avatar
you could put tape on and drill through the tape.. a brad point bit may splinter less.
My last project!
deniseO30 is offline
post #3 of 9 Old 10-06-2010
RichH's Avatar
For cutting into FRG or gelcoat, suggest that you first apply a 'strong adhering tape' and then saw into the FRG and the tape 'at a very shallow angle'. Dont 'force' the saw or saw with the teeth 'perpendicular' to the work.
For drilling, ditto the tape, and use either forstner or brad-point drill bits; not the common "v" tipped drill bits. A forstner or brad point will first cut a small circle into the gel before drilling out 'meat'. As with a saw, dont 'force' the drill bit .... or you WILL get 'chip outs'.
RichH is offline
post #4 of 9 Old 10-06-2010 Thread Starter
thanks. for the thoughts.
What do you mean by add tape at a "very shallow angle"? I'm thinking that a dremel tool with a saw blade will be my best tool for this?
caver504 is offline
post #5 of 9 Old 10-06-2010 Thread Starter
should I use bronze or nickle/zinc plated?
caver504 is offline
post #6 of 9 Old 10-06-2010
RichH's Avatar
Thinking that you were using a hand saw, you cut through the tape and FRG simultaneously and the saw held almost parallel to the surface ... not the usual ~45 degree angle to the surface so that the teeth make looooooog cuts so you dont break the gel/frg with the teeth.
RichH is offline
post #7 of 9 Old 10-07-2010
pedcab's Avatar
To cut GRP: An angle grinder with a thin cutting disc (plus a proper mask for yourself
To drill GRP: Just tune your drill bit point angle to a proper value for cutting plastics, say, 90.
Pedro
Portugal
pedcab is offline
post #8 of 9 Old 10-07-2010
To drill through gelcoat/fiberglass, first run the drill in reverse, this will burn through the gelcoat and prevent chipping, For larger holes, a holesaw used in the same manner after first drilling the pilot hole. For irregular holes I use a jigsaw with a special laminate blade that is made by Bosch, these blades are available from Lowes or Home Depot. Use masking tape to protect the surface you are drilling/cutting, I also use masking tape on the late of the jigsaw. What ever the tool used, slow and steady is the order of the day and if you do not do this regularly, always be prepared for the tool to bind a drill will try and twist out of your hands and a jigsaw will jump out of the cut potentially causing damage to the suface.
r.furborough is offline
post #9 of 9 Old 10-07-2010 Thread Starter
thanks for the help. looks like the rowing hardware is all drill stuff so it should be easier then I thought. I'm thinking about making a plastic spacer for the rowing socket so that it absorbs some of the force before transferring to fiberglass. Probably the same on back side of fiberglass. That way nuts and washers push on entire surface.
caver504 is offline
Drilling Hole in Fiberglass Hull sailak Gear & Maintenance 16 03-17-2011 10:37 AM
Cutting and drilling Acrylic 1/4" sheet for windows. zz4gta Gear & Maintenance 30 04-23-2009 12:06 PM
Cutting fiberglass dorade boxes sailboy21 Gear & Maintenance 5 12-06-2008 09:22 PM
Best tool for cutting fiberglass cockpit seat costaricanwannabe Gear & Maintenance 18 10-02-2007 07:04 PM
Cutting fiberglass aruggiero Announcements and Suggestions Box 3 07-19-2006 12:18 PM
