muffler replacement - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 5 Old 11-13-2010 Thread Starter
muffler replacement
I'm replacing the muffler on my 79 volvo penta md7a. I have the muffler off the foot but can't get the hoses off, so imagine I'll need to replace them as well. Does anybody have any tricks to keep in mind for muffler replacement (sabre 28 - it's tight down there), and can anybody tell me what kind of hose is now used for this kind of exhaust?
thanks
Rhodese is offline
post #2 of 5 Old 11-13-2010
imagine2frolic's Avatar
Have you tried pour hot water over the hoses? Is the muffler plastic? You can cut off the ends, and slice the neck of the muffler so it will fold out of the hose.......i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
imagine2frolic is offline
post #3 of 5 Old 11-14-2010 Thread Starter
thank you for responding - will try the hot water trick. It's the original muffler and is metal, corroded at the base and leaking buckets into the bilge. the hoses, which seem to be corroded to the two, top-in muffler ports, are that very stiff black kind and I'm hoping to replace them with something more flexible and easier to work with.
cheers
Rhodese is offline
post #4 of 5 Old 11-14-2010
They are probably very stiff, because they are rated for the purpose......i2f
post #5 of 5 Old 11-15-2010
QuickMick's Avatar
if you are replacing them you could just cut em off, but be advised there is probably a metal wire in there, so you might not want to use your fav knife
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
Atomic 4 Muffler Replacement Captnted Atomic 4 1 07-25-2009 09:43 AM
Exhaust/muffler etc brak Gear & Maintenance 5 06-11-2008 10:27 PM
atomic 4 muffler replacement Captnted Cal 1 06-11-2007 02:07 AM
A-4 Muffler replacement in Cal 34 Captnted Atomic 4 0 06-08-2007 10:17 AM
replacement muffler rbtpfe9 Gear & Maintenance 2 02-08-2005 12:06 PM
