Galley counter-ceramic tiles - Page 2 - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
 1Likes
post #11 of 11 Old 10-07-2012
Re: Galley counter-ceramic tiles
Has anyone thought of using the water-based epoxy stuff used over concrete floors in commercial kitchens? I had thought of making the top from epoxy saturated plywood. then placing in the sink, then covering the top with two layers of bi axial glass cloth and after it has been epoxy saturated, make the coving with epoxy and phenolic micro balloons and after that too has set--flood the top with the water-based epoxy filler compound--but leave out the pigmented resin flakes (unless you want them in there for some sort of uneven colour effect)
I had thought to cover the plywood sole as well--to use up the rest of the kit.
Mike Banks is offline
Replacing galley counter L124C Gear & Maintenance 7 02-25-2009 02:15 PM
Yanmar rev counter Omatako Gear & Maintenance 6 06-26-2008 03:29 AM
Counter Tops mcain Gear & Maintenance 23 02-15-2007 10:21 AM
Repair of galley counter ricka Catalina 2 12-02-2006 10:32 PM
Epoxy and ceramic drynoc Gear & Maintenance 0 12-27-2005 11:43 AM
