How do you clean your bottom? - Page 3 - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
 1Likes
post #21 of 25 Old 12-02-2010
Fstbttms,
Don't know if you have any experience in this area, but do you have a recommendation for what to use on a racing-smooth bottom, painted with VC-17, for getting off the relatively soft growth we get on our bottoms in the Great Lakes? This stuff blows right off with a power washer, if you haul to clean. It may not seem like much to our ocean-going brethren, but, when racing, every fraction of a knot can count .
Depending on how often we sail, I have to pull the knotmeter transducer several times a year. All it takes to get it "clean" is a bucket of water and a small rosin brush.
Thanks,
Jim
SEMIJim is offline
post #22 of 25 Old 12-02-2010
I don't discuss my member
Fstbttms's Avatar
I don't have much experience with VC17, 'cause we hardly ever see it here in a saltwater environment. But I know it's super easy to scrub off and I would recommend using something very soft, like a microfiber towel or diaper to clean it with.
Fstbttms is offline
post #23 of 25 Old 12-02-2010
zz4gta's Avatar
To clean your own bottom you need a sponge, diaper, towel for soft paint. If its a hard racing bottom you can use a scotch brite pad. Pretty much the softest thing you can use to clean it, as FastBottoms said.
I've tried the PVC thing, and it didn't work for me. The flossing with a towel actually worked pretty well, but you can't get the keel. There's no easy way to do this. If you want to do it right, you'll have to get wet. And chances are, you're going to get cold too.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #24 of 25 Old 12-23-2011
Check with your state department of ecology website. Here in Washington it's illegal to scrub in the water bottoms with ablative bottom paints. Hard paints are OK. The fine's about $10K
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #25 of 25 Old 12-23-2011
remetau's Avatar
Toilet paper thank you!
Don & Diana
sv Re Metau an HC33t
remetau is offline
How to Clean a dirty bottom jephotog Gear & Maintenance 14 09-08-2009 11:55 AM
keel clean up and bottom paint hobie61 Gear & Maintenance 1 04-30-2009 07:51 AM
Clean mean lines Giulietta General Discussion (sailing related) 16 01-29-2009 05:24 PM
How do you clean the bottom? razorseal Gear & Maintenance 5 02-23-2006 12:06 PM
Diver to clean bottom..how much $ Wega24 Racing 5 08-19-2002 08:03 AM
