Self Steering - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 7 Old 02-18-2011 Thread Starter
Self Steering
Would like to buy used but good self steering gear for 32ft sailboat. maineboat
maineboat is offline
post #2 of 7 Old 02-18-2011 Thread Starter
goodluck.maineboat
post #3 of 7 Old 02-18-2011
Lightbulb Swap Meet - be early...
Seems like every April at the big swap meet in Seattle someone shows up with a used Aries or Monitor. Other brands, too, like the old (but good shape) Sailomat I saw a couple years ago.
So try to attend your local swap meets and have some cash and be ready to negotiate a deal!
L
olson34 is offline
post #4 of 7 Old 02-18-2011
mitiempo's Avatar
Look on Craigs List or similar - in boating areas used Monitors and other vanes often are listed.
Brian
mitiempo is offline
post #5 of 7 Old 01-05-2012
aries wind vane
I have a used aries wind vane that came with the boat I bought. I don't know a lot about them, but was told by person I bought my boat from that it is complete, just needs to be rebuilt. I was going to list it, but if you are interested, lets see if we can make a deal.
813.362.6553
jeffr-here is offline
post #6 of 7 Old 01-17-2012
deliveryskipper.com
WindPilot
I had a Windpilot vane on my Newport WINDPILOT: selfsteering under sail It was the most used accessory on the boat. Simple, quite, strong and reliable. You had to get the boat pointed and the sails set right for it to work well. I sailed from SF to Mobile, AL with it, short handed and it never let us down. I chose it because it was the best looking one out there, just so happened it worked perfectly.
As with women good looks are not a reliable indicator of performance. But if you are patient and skillful you can get them to do what you want most of the time.
Capt. N Shaw
Captnshaw is offline
post #7 of 7 Old 06-24-2012
Re: Self Steering
My current love came equipped with a Hydrovane. What I really like is that the auxiliary rudder is truly that, and will steer the boat should something nasty happen to the main rudder.
Previously I had a Tasmanian-made system which was all-stainless, really strong and looked great, but I never got it to work right. I'm not saying it was no good, just that I never mastered it. Also it needed a good 10 knots of breeze to steer. The Hydrovane is alloy and doesn't look as pretty as stainless, though it looks as if it would take a lot to break it. It is easy to use and steers down to about 5 or 6 knots of breeze. You do have to either antifoul the aux rudder or pull it once every two weeks or so to clean it before the barnacles get a grip. The rudder does not simply swing up like some other types - you have to hang off the transom and pull a pin. It can be a bit tricky getting it back on to its shaft and aligning the pin, so don't attempt this at sea! And the rudder doesn't float, so it needs to have a safety line attached to the boat.
Bear in mind that none of these things work on a dead downwind run.
arvicola-amphibius is offline
$3 Self Steering vega1860 General Discussion (sailing related) 4 06-22-2010 10:28 PM
self-steering sneuman Gear & Maintenance 1 06-10-2003 07:44 PM
