my md5a diesel wont tickover,any ideas? - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 3 Old 06-17-2011 Thread Starter
Angry my md5a diesel wont tickover,any ideas?
My volvo penta MD5A engine wont tick over.I've set up the throttle/governor linkage as per the manual. I thought it might be a worn injector pump,so have just changed that and checked the timing at the same time.I can adjust the throttle stop so that it stalls when cold but ticks over at about 1000 RPM once it has warmed up.It should tick over around 5/600 RPM.Any ideas/advice /suggestions very welcome.Thanks in anticipation.
tabnabtoo is offline
post #2 of 3 Old 06-17-2011
Have you checked the fuel and air filter?
Have you checked the injectors are in spec?
Unlikely but valve clearance could also be an issue.
limeyrock is offline
post #3 of 3 Old 06-18-2011 Thread Starter
Thanks limeyrock, fuel and air filters ok. Checked valve clearances today but no change. Injector was going to be the next step.Watch this space!! Thanks again.
Volvo-Penta Diesel MD5A/110S - Cold Start/Stop Control jbdoucet Diesel 4 08-06-2014 09:47 AM
Diesel wont rev CapnSantiago Gear & Maintenance 8 06-15-2011 02:42 PM
need ideas for gravity feed diesel tank piav Gear & Maintenance 11 11-13-2009 01:40 AM
Diesel acting up, ideas? ilnadi Gear & Maintenance 12 03-17-2006 04:09 PM
Folding Prop for Volvo MD5A mikehoyt Gear & Maintenance 0 12-02-2002 05:25 AM
