Marine Head (Peggie ? ) - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 5 Old 07-31-2011 Thread Starter
I have a Jabsco 29090-3000 on my Cat 320. This is the "Twist N Lock" model.
With the fluch control lever in the shut position while emptying the bowl, I have pressure or resistance which can be eleminated to permit emptying the bowl if I hold the flush control lever fully over by hand while finishing the pump. Which parts need to be replaced? Is there a diagnostic procedure? I have the owner's manual with exploded view with part numbers.
John/Illinois is offline
post #2 of 5 Old 08-02-2011
Are you looking for Peggie Hall - The Head Mistress? Check next door at SailboatOwners.com
DonScribner is offline
post #3 of 5 Old 08-03-2011
Normally when one part in the head needs replacing there are others that are close to needing replacing. I would buy the standard Jabsco refit kit and replace all the parts that comes in the kit. It is very simple.
If you are up to it you can always take the thing apart and rinse all the rubber valves etc. in vinegar and then rub them with a bit of cooking oil before installing them again (a bit of a shitty job).
To maintain the head in working condition as long as possible add vinegar directly in the bowel and pump it slowly through the system over an hours time a few times a year. Adding a few spoons of cooking oil directly in the bowl regularly and then pumping it through also works miracles on the Jabscos in terms of durability and smoothness in the pumping action. As soon as I hear the smallest squeak I give it a bit of cooking oil it makes a mega difference - I promise.
"OO" is offline
post #4 of 5 Old 08-03-2011
Wink You didn't ask an opinion, but...
Not to put too fine a point on it, but....
One of the best ways I have ever found to 'fix' a Jabsco (cheap!) head is to replace it with Raritan PH2.
LB
olson34 is offline
post #5 of 5 Old 09-01-2011
I did this once. Sat on the dock with a toothbrush cleaning crusted salt and poop and the brush flicked stuff into my face.
yeah yeah, don't do that. duh.
Here's the thing though: the refit kit is like 60, and an entire pump is 99. (they used to be only $10 or so apart which made it a REALLY easy choice)
but even for $40, it's SOOOOOOO much better to just replace the whole thing
and yeah, after the second one died, I got a raritan
xymotic is offline
Marine Head - too small for the job rockDAWG General Discussion (sailing related) 25 02-21-2011 09:41 PM
Marine Head snider General Discussion (sailing related) 16 05-20-2008 11:26 PM
marine head confusion marinoinPV Gear & Maintenance 4 01-25-2008 02:39 PM
Clogged Marine Head mathislaw1 Gear & Maintenance 39 03-30-2007 08:18 PM
Using a Marine Head Dan Dickison Gear and Maintenance Articles 0 08-14-2002 08:00 PM
