Depth sounder advice needed - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 2 Old 09-06-2011 Thread Starter
I have an Apelco 265 Depth sounder. The display gradually went belly up. First getting darker, then a blister and finally it's not readable. I called the people at Raytheon and they no longer sell replacement parts for this model. The guy I spoke to said that theoretically I could adapt the transducer it to another display but it would be very expensive. (I imagine frequency and plug configuration are issues in mixing displays.) I hate to take out/destroy the old transducer, glued through the hull. Is there another alternative?
Thanks
Epicurean is offline
post #2 of 2 Old 10-18-2011
Transducers have several common freqs. If your new sounder is compatible {same freq} and you can adapt the plug end it should work.You dont need a dual freq for a simple depth reading But the technology is always changing and our need to upgrade a constant factor. Good luck.
Capt Len is offline
New Depth Sounder / Old Transducer (How To) Maine Sail Gear & Maintenance 10 07-09-2011 12:35 PM
Depth Sounder Re-Fit? Seafire327 Gear & Maintenance 8 03-27-2011 02:09 PM
Depth Sounder Options tip Electronics 23 03-11-2011 01:34 PM
Depth Sounder Tranducer chuckg Gear & Maintenance 10 02-01-2010 02:51 AM
Depth Sounder ARTIMES Gear & Maintenance 1 07-23-2006 02:33 PM
