rub rail replacement - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 2 Old 12-01-2011 Thread Starter
I need to glue my rub rails back on they remove real easy to easy. So I took them off and clean them and the deck hull seem and now have to glue them back on What glue will do the trick so the don't come off under load. My boat is a Newport 30, 1976 vintage. Epoxy doesn't seem like the right stuff maybe gorilla glue? any recommendations or ideas would be appreciated Thanks Stu
fstuart is offline
post #2 of 2 Old 12-01-2011
JedNeck's Avatar
I would use a little silicone...but only small blobs at the largest intervals feasible.
JedNeck is offline
Tags
glue , newport 30 , rub rails
rub rail ncsc Cal 15 09-18-2014 07:40 PM
Toe Rail Replacement ambianceack Gear & Maintenance 6 08-07-2013 01:29 PM
Toe Rail Replacement: Teak or Mahogany snook91901 Gear & Maintenance 15 10-31-2011 03:57 AM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 10:28 AM
Bow Rub Rail Replacement eobpt Gear & Maintenance 2 10-13-2008 07:34 AM
