-   SailNet FAQ (http://www.sailnet.com/forums/sailnet-faq/)
-   -   When to bleed high pressure side?8 (http://www.sailnet.com/forums/sailnet-faq/82754-when-bleed-high-pressure-side-8-a.html)
RPMRPM 01-16-2012 12:29 PM
Does the high pressure side need to be bled after re-torque head & adjust valves on yanmar 2gm20f?
dorymate1 01-30-2012 09:30 PM
Bleed it
Only need to bleed if fuel system is openned during repair. If you find it nessesary to bleed to start engine then you may have a air leak in the system. after priming to injector pump on a 2 GM will need to crack injector lines @ injectors and crank engine until u see fuel cone out.
If you've never done this before best to get help the first time. AL
PS from a real mech. not a friend who thinks he is!!
jrd22 01-30-2012 10:54 PM
Yep, what alpatn said. If you didn't disconnect any fuel lines you shouldn't have to bleed anything.
Capt Len 01-31-2012 11:36 AM
If you are just learning about your engine, it might be an opportunity to do it as a practice run, dry or full monty. Less thinking to do after filter change on a lee shore.
