I should know this - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 3 Old 02-03-2012 Thread Starter
lajimo's Avatar
I should know this
Went out singlehanded this am and had steady 15 with gusts to 20, short chop 2-3 ft and whitecaps. I unfurled the jib (130) and had a nice couple of hours on a close reach in and out. When it came time to furl the jib I turned on the engine, turned into the wind, set the autopilot and attempted to furl. A combination of chop and gusts slightly askew the wind kept pushing the bow around and putting too much wind into the sail and I couldn't furl. After floundering around awhile I finally turned off the auto and let go the jib lines while holding the wheel with my foot and furling. Got it all in but with a real birds nest of tangled sheets. Any suggestions on what I should have done?
lajimo is offline
post #2 of 3 Old 02-03-2012
Furling always works best by bearing off, heading on a deep broad reach and furl the sail in the lee of the main.. Much less strain on the furling gear, esp in a breeze. Sounds like you had plenty of sea room for that. You can do this under sail... another good reason not to get into the habit of headsail-only sailing.... even a reefed main would have helped.
Faster is offline
post #3 of 3 Old 02-03-2012 Thread Starter
lajimo's Avatar
Good point - I will try that next time, thanks.
lajimo is offline
