Grabrail Covers - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
 3Likes
  • 1 Post By Squidd
  • 2 Post By Sailormon6
post #1 of 5 Old 02-16-2012 Thread Starter
Grabrail Covers
Ok, so I'm going to start some light sewing projects to learn some basic lay out rules. Does anyone have some concise instructions for making grabrails covers?? There's 4 of them of my CheoyLee 38.
Thank you
svmosaic38 is offline
post #2 of 5 Old 02-16-2012
Superior Sailor
Squidd's Avatar
I would start with some cardboard templates, you already know the width, and from there it's basic pattern making...lay out, add fold, add sew to lines, etc..
svmosaic38 likes this.
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #3 of 5 Old 02-17-2012 Thread Starter
Thanks Squidd. I have an email into Sailrite. I hear they have a printable version of making rail covers. I am but a novice, so making a template is a good idea alright.
post #4 of 5 Old 02-17-2012
You don't need a pattern. Lay your sunbrella fabric over the grab rail with one edge just touching the deck all along the length of the rail. Mark the point where the other side just touches the deck on the other side of the grab rail. I add about 3/4" to it, which permits a hem allowance of about 3/8" on each side. Then cut the fabric, making sure it's long enough to extend the whole length of the rail, plus about an extra 3 inches. Then sew the 3/8" hem on both sides of the fabric. Next, lay the fabric over the grab rail, with the hem on the outside. (When you sew the ends of the cover, the cover will be inside out. After the ends are sewn, you'll turn the cover inside out again, and the hems and seams will be hidden inside the finished product.) Then mark the line where the seam will be sewn at each end of the cover. Sew each seam along that line. That's all there is to making the cover.
I use velcro to hold them on the grab rail, and mine held through a hurricane. I sew about a 1" length of velcro in the middle of each loop of the grab rail. When you put on the covers, all you have to do is pinch the fabric at each point. Easy on - easy off!
tip: When you sew the hems, use a zigzag stitch. It will help prevent the cut edges of the fabric from unravelling.
Sailormon6 is offline
post #5 of 5 Old 02-20-2012 Thread Starter
Thanks, Sailormon6, that's the kind of help I really needed, a brief step by step walk through. Such are the needs of the bright green beginner....
I suppose I'll start with some scrap material too make sure I'm doing the fwd and aft rounded edges right...
Thanks again, and to all who replied. I'll be making sails before ya's know it. Quite sure you'll be able to spot them!!!
Gas Tank Covers hartman42 Gear & Maintenance 3 04-11-2011 05:50 AM
porthole covers charlienpam General Discussion (sailing related) 7 06-13-2010 07:38 AM
Fender covers - any use? ardoin Gear & Maintenance 14 05-08-2009 07:31 PM
Winter Covers? danielgoldberg Gear & Maintenance 89 12-06-2008 02:03 PM
Bimini Covers KPBaker Gear & Maintenance 3 03-08-2002 02:26 PM
