Compacting styrofoam - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
 1Likes
  • 1 Post By hellosailor
post #1 of 7 Old 02-20-2012 Thread Starter
I found a simple way to deal with styrofoam onboard. I just put it in a litre jar, add a spoonful or two of laquer thinner and put the lid on. The foam dissolves, and after six months of use ,the jar is half full of gooey plastic. Occasionally I have to add more thinner. If I leave the lid off for a few days, the thinner evaporates, leaving a hard lump of styrene plastic, which can be easily disposed of. Gasoline also works , but is slightly slower.
Brent Swain is offline
post #2 of 7 Old 02-22-2012
That is an interesting way of disposing of styrofoam...Add a spark and it will burn long and hot for awhile! Sounds like a dangerous solution.
Schock - New York 36
Portsmouth, RI
mm2187 is offline
post #3 of 7 Old 04-01-2012
Re: Compacting styrofoam
We used to make "napalm" that way as kids.
Never through it would have a practical purpose. I'd probably do it outside though, IIRC there's some pretty nasty chemicals released when you dissolve it.
Jgbrown is offline
post #4 of 7 Old 04-01-2012
Why waste your solvents?
Put the foam in a mesh bag, add a weight, lower it down 100-150' on a line. The water pressure will compact it nicely. The deeper you lower it, the more it will be compacted. Instantly, no need to wait a week, no solvents required.
DivingOtter likes this.
hellosailor is offline
post #5 of 7 Old 04-01-2012
Here in Naniamo most plastics including styrofoam are recyclable .If not in your neck'of 'woods complain to local officials for greener atitudes. All plastics can now be made into liquid fuel with a new pressure and heat distillation process.Just a matter of scale and we can harvest the Pacific gyre. .
Capt Len is offline
post #6 of 7 Old 04-02-2012 Thread Starter
Takes seconds for laquer thinner to dissolve it, minutes for gasoline. Then, when the jar is full, leave the lid off and lit evaporate. It doesn't make thinner or gas any more dangerous than it was originally.
post #7 of 7 Old 05-16-2012
Otter
DivingOtter's Avatar
interesting you mentioned that, my brother in law has a company that turns plastics into fuel
DivingOtter is offline
Insulation: Reflectix or Sheet Styrofoam coreywoodworking Cruising & Liveaboard Forum 12 01-15-2011 01:20 PM
White Styrofoam Blocks tager Sailboat Design and Construction 25 09-15-2010 08:23 PM
How much styrofoam bouyancy do I need? bottomfeeder Gear & Maintenance 2 02-02-2004 02:33 PM
