Tip of Mast hit bridge... - Page 2 - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
 1Likes
post #11 of 35 Old 03-12-2012
Re: Tip of Mast hit bridge...
Where did the top foot of the mast go? Is it hanging there? Are all the shrouds and stays still attached?
I have a feeling that you only tore off the accessories on top of the mast, light, windex, static discharger, wind speed, whatever you had.
If so, have her inspected by a professional rigger to be sure you didn't "almost" break something that might let go at the worst time. Rigging is safety gear.
On the other hand, you say your mast is straight. Ironically, many masts are forcibly bent when the backstays/forestay are tuned properly. Maybe you did damage some of the rigging. Have her checked. If you're new to this, you're going to need someone very familiar to readjust the stays and shrouds when you put the mast back anyway. You can't just guess.
Sorry to hear about the nasty lesson.
Jeanneau 54DS
Minnewaska is offline
post #12 of 35 Old 03-12-2012
If the o/b was submerged I would want to check the oil, for a start. If the engine oil is water contaminated, running it is not a great idea. Also dry all the connections in the ignition system, and take a look at the gasoline. If the bleed valve was open at the time, there might be water in the gas.
I would not actually have tried starting it before removing the spark plug and checking inside the cylinder for water.
MarkSF is offline
post #13 of 35 Old 03-16-2012 Thread Starter
ranger22owner
Hey guys so the pictures are not too clear but here is the mast from afar. Also regarding the motor, it is better now I just dried out the inside and she runs like a beauty!!
http://emob1048.photobucket.com/albums/s373/Noah_Kettler/Mobile%20Uploads/IMG_2990.jpg
ranger22owner is offline
post #14 of 35 Old 03-16-2012
Picture needs to be bigger... can you try pasting your 'IMG CODE' link option?
Faster is online now
post #15 of 35 Old 03-16-2012
If there is any lube oil, lower unit lube oil, anything like that in the engine?
If you don't want to change it, at least check it very carefully ot make sure there is no water in it. Any milky or foamy appearance, there's water in it.
hellosailor is offline
post #16 of 35 Old 03-16-2012 Thread Starter
ranger22owner
Oh and sorry for the unexplained picture above. My boat is the ranger 22 (twilight zone) in the front right. I really cannot tell if my mast is in fact bent to the point of getting a new one. The picture below is the tip of the mast of what is left. Will I be able to keep my mast? None of the lines have been affected nor the base of the mass on the ceiling of the cabin.
http://m1048.photobucket.com/albumview/albums/Noah_Kettler/Mobile%20Uploads/IMG_9308.jpg.html?o=1
post #17 of 35 Old 03-16-2012
Your mast looks like it might be OK, but the picture is too small and low res to be certain... here it looks like just a VHF antenna that is damaged.
The rigging appears intact, as does the masthead crane etc..
Could be you just got off with a warning.
post #18 of 35 Old 03-16-2012 Thread Starter
ranger22owner
Oh man I am sorry I didnt realize the size of the picture. Here is a better one of the lines. Hopefully this helps...
post #19 of 35 Old 03-16-2012
That's much better! I think you're going to be OK... the 'looking up the mast 'view is most helpful.. even your VHF may still work despite the 'off kilter' antenna.
You certainly didn't 'break off the top foot or so', as you seemed to indicate earlier.
post #20 of 35 Old 03-16-2012 Thread Starter
ranger22owner
That is very good news. Maybe it wasn't a foot down that broke off maybe it scraped a foot down. So do you think I will be fine if I decide to pull up the sails today?
How do you get 80 ft of mast under a 65 ft bridge? Treborbmal General Discussion (sailing related) 5 09-19-2011 09:30 AM
What to do about a low bridge? hudi11 General Discussion (sailing related) 26 04-27-2010 04:17 PM
bridge clearence fcsob Morgan 5 05-26-2008 06:25 PM
Sailboat mast scuffs underside of bridge - Myrtle Beach Sun News NewsReader News Feeds 0 05-27-2007 04:16 AM
Rhodes 22 mast lowering under bridge GeneStory Gear & Maintenance 1 10-20-2001 08:48 PM
