Spreader Lights - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
post #1 of 2 Old 04-29-2012 Thread Starter
Spreader Lights
Our daughter purchased a set of spreader lights for me for Christmas. I need to mount them very soon, as the boat will be going in shortly. I have wooden spreaders that fold when the mast is down. The boat is a Ranger 26 and the mast is 3 feet long. The new power wire is already drilled through, and coiled in the starboard side of the mast. I'm fairly mechanical, so I'm nbot concerned, but new to sailing. Can anyone give me some advice as to wher on the spreaders the lights should go, and should I run the Port lighht wire through the mast. I have Halyards going up ob both side of the mast.
Any suggestions or problems I may not be thing about would greatly help.
I'm thinking 1/2 way between the mast and the end of the spreader, but I really don't Know.
Thanks alot
jaybird2719 is offline
post #2 of 2 Old 04-29-2012
Re: Spreader Lights
Thanks alot
About halfway out on the spreader sounds perfect.
I normally split the wire into a Y and leave the junction inside of the mast. Or rather push it back inside the mast. Then I run each leg out of the mast under the spreader and out to the light.
It's best to have the wire running up the mast inside of a conduit. Otherwise, the wires will probably make some noise slapping the inside of the spar. They also may eventually get chafed by the halyards.
knothead is offline
Spreader Lights 2012? Joesaila Electrical Systems 3 04-12-2012 01:40 PM
LED Spreader lights, practical? brands? sailbear50 Electrical Systems 3 02-07-2010 10:02 PM
Need new spreader lights. L124C Electrical Systems 2 07-31-2009 09:49 AM
Identification Lights & Nav Lights on Sailing Vessels Boasun General Discussion (sailing related) 10 02-13-2009 09:42 AM
Spreader lights: One or two? groundhog Gear & Maintenance 13 05-25-2007 08:07 AM
