Fogged over plastic panels - SailNet Community
SailNet FAQ This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
 2Likes
post #1 of 13 Old 12-09-2012 Thread Starter
Is there any home remedy to clear up plastic panels on dodgers?
Hale
halequigley is offline
post #2 of 13 Old 12-10-2012
Zanshin's Avatar
Re: Fogged over plastic panels
I use the Macguires compounds and don't know if a single home-made remedy will suffice, since the first compound contains mild solvents and abrasives and the second then has the oils and compounds to fill in and un-fog the plastic.
Is your dodger scratched or only fogged?
Zanshin is offline
post #3 of 13 Old 12-10-2012
It depends a bit on what your panels are made from. For Eisenglas, you can buff with 210 Plus, but I'm told you will ruin Strataglass, if you do so. From the sounds of it, you probably can't really ruin it any more than it already is. I would probably give it a shot, knowing that replacing the glass was my fallback.
I've hand buffed with the stuff, which requires some work, but I'm told one can use a power buffer for good results.
http://www.amazon.com/210-Plus-Plastic-Scratch-Remover/dp/B006L66Y3Y
Jeanneau 54DS
Minnewaska is offline
post #4 of 13 Old 12-10-2012
And I will just chime in and say that polishing should remove the fogging but it will tend to come back pretty quick. After polishing it it's a good idea to use a good uv protectant like 303 which will help prevent that.
tschmidty is offline
post #5 of 13 Old 12-12-2012 Thread Starter
Thanks for the feed back. I bought some Mageires Plastix and will give it a whir.
Hale
post #6 of 13 Old 03-04-2013
Otter
DivingOtter's Avatar
If its Lexan use toothpaste. The toothpaste acts as an abrasive without further scratching but will clean it up nicely. It did on my boat anyway, as well as my dive hats..
DivingOtter is offline
post #7 of 13 Old 03-04-2013
OK guys, different plastic, same problem. The headlight lenses on my car are very cloudy. What do you suggest I use to clean them up? It's a 10 year old car.
zeehag likes this.
Catalina 34
chuck53 is offline
post #8 of 13 Old 03-04-2013
Once known as Hartley18
Classic30's Avatar
Dock
How about... Your credit card at an Auto Parts store?
zeehag likes this.
Classic30 is offline
post #9 of 13 Old 03-04-2013
Asleep at the wheel
jimgo's Avatar
Harbor Freight Tools sells a set for polishing your headlights. There's also some very fine sandpaper made by a company called Micromesh. Their paper was designed for polishing airplane cockpit windows.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #10 of 13 Old 03-07-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Meguire's also makes a plexi polish for MC windscreens and such. Always worked on mine and I sed it as final on the headlamp covers on the auto after successively finer white compound.
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
Plastic trim brak Gear & Maintenance 6 12-10-2010 10:31 PM
Plastic pollution chris_gee General Discussion (sailing related) 98 10-31-2009 02:07 AM
Fogged Compass NCC320 Gear & Maintenance 8 04-27-2009 06:02 PM
Plastic paint for tired looking plastic parts Goodnewsboy Gear & Maintenance 3 01-01-2007 06:15 AM
