-   SailNet FAQ (http://www.sailnet.com/forums/sailnet-faq/)
-   -   Ford Lehman 120 Tachometer Connection (http://www.sailnet.com/forums/sailnet-faq/99176-ford-lehman-120-tachometer-connection.html)
Craig Robelen 05-05-2013 10:59 AM
My tachometer has stopped working when the engine is running although it responds when I turn the ignition key. I had a flood in the bilge and need to locate where the tach is connected to the engine to investigate if that connection is corroded. I have yet to locate where that connection may be. Any suggestions?
CapnChuck 05-05-2013 02:41 PM
Re: Ford Lehman 120 Tachometer Connection
The tach takes off the alternator on the FL120. Your post doesn't make sense. How can it respond when you turn the key if the engine is not running? Chuck
chuck53 05-05-2013 05:52 PM
You are in the wrong forum to ask this question.
Go to the Gear and maintenance forum, diesel engine sub forum and ask.
Craig Robelen 05-05-2013 07:50 PM
What I was saying is that when I turn the ignition key the Tach jumps but once the engine is running not does not register the RPMs
Craig
Craig Robelen 05-05-2013 07:54 PM
What I was saying is that the tach jumps when I turn the ignition key but dyes as the engine begins runnning. Any suggestions?
chuck53 05-05-2013 09:01 PM
Again, you are in the wrong forum.
You need to be in gear and maintenance...sub forum, diesel engines.
desert rat 05-05-2013 09:20 PM
dead diode converting the ac from the pickup to dc for the meter.
