-   SailNet FAQ (http://www.sailnet.com/forums/sailnet-faq/)
-   -   Bristol 30 hull ID (http://www.sailnet.com/forums/sailnet-faq/99479-bristol-30-hull-id.html)
gentryd 05-13-2013 08:41 PM
Bristol 30 hull ID
Hi everybody, I recently aquired a 1972 Bristol 30. State of Texas requires hull ID rubbing to register/ title. I've looked all over the transom which is where I would think it should be (as well as the sides and interior). Anybody with knowledge of Bristol's have any suggestions? Any and all help greatly appreciated.
cthoops 05-13-2013 10:07 PM
Re: Bristol 30 hull ID
Congrats on the boat!
There is a very active Yahoo Group for Bristol owners that you could try. I've found everyone to be very helpful. Even if they can't help to solve this particular issue, it's a good group to get familiar with.
Good luck.
BubbleheadMd 05-15-2013 06:13 AM
1972 is prior to when hull id's were required. Well, they were implemented at the end of 72. You probably don't have one.
Jeff_H 05-15-2013 09:35 AM
Bristols typically have a brass or aluminum plaque with the hull number on it. The plaque was generally mounted in the cockpit or in the companionway on the beam over the ladder. This will not be the same as HIN (VIN) and will generally only be a two digit number.
MarkSF 05-15-2013 11:10 PM
On my 31.1 it's on the transom, right at the top.
Suggestion : if you can't find it, get a plate made with the number on, bolt it to the hull, and take a rubbing of it.
gentryd 05-17-2013 08:42 PM
Thanks all for the info. Never did find anything. MarkSF maybe yours the best idea. Went to TX parks and wildlife today, they say only option to bring boat to their office on Thursdays, game warden will inspect and assign number. Bring a 30 ft w/ 5' 3" fixed keel sailboat to their office????
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
