03-19-2010
1 gallon of water weighs 8.35 lbs
So a 55 gallon drum when submerged displaces 55 gallons of water. Which means it takes 55x8.35 = 459.25 lbs to submerge the barrel. I would go with 400 lbs for a 55 gallon drum, because this calculation does not take into account the weight of the drum.
Originally Posted by rosskowh
i like the drum idea, is a 55 gallon drum enough to float a 350 lb anchor???
97 XR600R Honda Dual Sport Motorcycle
98 18' Avon RIB w/ 90 HP 4 stroke Yamaha
95 TDI Passat VW Wagon
05 2500 140" sprinter van w/ v3 frybrid kit
08 Laser Pro #194171
Sail Smart, Sail Hard, Then think about Sailing Fast !!!!!
Some day I will sell everything, buy a 50 ft sailboat, and turn left at the Columbia River Bar To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
