Go Back   SailNet Community > Welcome to Sailnet > SailNet FAQ's
SailNet FAQ's This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
Old 08-17-2010
allegr is on a distinguished road
spinnaker pole attachment - which way is up?
Have seen different approaches to spinnaker pole attachment; i.e. with the opening of the jaws facing up and, with the jaws facing down towards the deck. Good arguements either way.
The set up is standard, a pair of sheets, pair if guys, foreguy, topper. The pole has a bail which is located about 15 inches from the outer end of the pole which I assume is for the topping lift. This means the pole jaw opening would face down. The downhaul is attached ( I assume again ) at the very end of the pole with a single block attached with a snap shackle where I lead the foreguy line to the deck. However, the pole could be reversed so that the opening of the jaws face up and the associated foreguy and topper attached correspondingly.
So, which way will help tripping, with the jaw opening facing down towards the deck or up? Seems with the jaw opening facing down, the after guy will drop easier,.. if the after guy is eased prior to tripping. On the other hand. if the jaw opening faces up, it might be easier just to lower the pole down,... the after guy will spring up freely.
Thoughts and recommendations are appreciated; preferences for light vs heavy air spinn sailing, proven approach, etc.
Old 08-17-2010
Jeff_H's Avatar
Super Moderator
Jaw opening facing up.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 08-17-2010
HighSeasHarry is on a distinguished road
Jaws up. No two ways about it.
Old 08-17-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Originally Posted by allegr View Post
Good arguments either way.
Nope. There's no argument for jaws facing down, and don't let anyone tell you otherwise. Those are the people who have never worked a foredeck. Jaws go up. All the time, every time. Otherwise, if the pole skies, it's locked in on the mast. Good way for things get fubar'd quickly.
What kind of boat do you have? Specifically the size.
Merit 25 # 764 "Audrey"
Old 08-27-2010
aarhus's Avatar
aarhus is on a distinguished road
Nice timing; I had exactly the same question, but had not heard arguments for either one (learning stage).
The pole getting locked on the mast is a big argument... is it the only one for jaws facing up? Are there any for jaws facing down besides "it feels more comfortable"?
Edit: I'm on an H-boat, around 27ft.
Old 08-27-2010
which way is up
Thanks to all with your comments, appreciate it.
Looks like all have confirmed which is the right approach; i.e. jaws facing up and with all of the comments it just seems right to now.
Thanks again1
Old 08-27-2010
Besides the "locked-on-mast" issue, with the pins up when you are gybing in any breeze at all the guy will lift out of the outboard jaws readily when you pull the pin. The guy would also be trapped except in really light air, requiring the pole to be rolled to release the guy if it was upside down.
1984 Fast/Nicholson 345
Old 12-07-2010
msmith10's Avatar
Junior member, rest old
msmith10 is on a distinguished road
Faster is right- jaws open up lets the chute lift out of the pole. Conversely, when using a whisker pole, I face the outboard jaw opening down- the jib tends to fall out of the jaws when they're opened.
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
Sabre 34 parts for sale wemsail Sabre 24 02-06-2012 07:42 PM
Spinnaker pole height: no downhaul, no adjustable height aarhus Learning to Sail 5 08-16-2010 05:37 AM
Cal 21 Spinnaker? sailnova Cal 0 08-13-2010 10:55 AM
