Go Back   SailNet Community > Welcome to Sailnet > SailNet FAQ's
SailNet FAQ's This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
Old 12-14-2010
pfirth is on a distinguished road
slow warming diesel
I have yanmar 2qm15 installed in my 30' S2 9.2c. Having taken care of the problems of water and solid contaminants in the fuel tank, the engine runs well again, but will not idle without a lengthy warm up period. I'm going to try running some injector cleaner through the system. Any other suggestions out there? Thanks
Old 12-14-2010
jackdale's Avatar
jackdale will become famous soon enough
Is the engine actually warm? Stuck thermostat? Wrong thermostat?
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 12-15-2010
Could be a stuck thermostat, I haven't changed it. I'll check if it's running warm before able to idle but suspect it's some left over debris in an injector. thanks for the suggestions. I'll post a fix when it happens.
Old 12-15-2010
centaursailor's Avatar
Senior in age only!!!
centaursailor is on a distinguished road
What do you consider a long warm up period, my raw water cooled Yanmar GM 30 need a a good few minutes to push the water round the engine and out the exhaust before idling smoothly. I keep her about quarter speed till she clears the exhaust then all is smooth.
Brian G
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
Old 12-18-2010
zeehag's Avatar
zeehag is on a distinguished road
yannies run a lot cooler than other engines. might not always warm yer bath water..mine reads art 120-140 for running--i used sunshowers in my ericson.. more efficient. i donot keep a water heater for this boat-- i use sunshowers still.
formosa 41 and ericson 35mII
formosa and cat and i are cruising mexico at present, southward , ever southward....
Global Warming Debate HoffaLives Off Topic 4227 2 Weeks Ago 12:07 PM
Warming Batteries Neicy Gear & Maintenance 8 01-03-2010 02:05 PM
Globial warming travler37 Politics/Religion/War/Government 12 02-02-2009 09:23 AM
How slow is too slow before you use the motor? FarCry General Discussion (sailing related) 30 10-07-2008 01:09 PM
Vote For Alex...stop Global Warming Giulietta Off Topic 69 12-20-2007 08:21 AM
