Go Back   SailNet Community > Welcome to Sailnet > SailNet FAQ's
SailNet FAQ's This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
Old 01-30-2011
SailboatsRock is on a distinguished road
Question Removal of Bulk Heads
Ok, here's a good one. I want to remove the radio station and chart table bulk heads in my 27' Morgan. Pros and Cons? I am trying to extend my sitting room room as I remodel the interior and I want open up the rear quarter berth. A few suggestions would be great.
I believe the both sides of the chart table touch the deck, but I am unable to find any attachment. Of course, with the Morgan being the boat that it is, the deck has popped up from most of the bulk heads due to racing in the past from the previous owners. As far as the storage goes, one small cabinet will be lost, but I will gain under the seating cushions as well as, the new shelving. Kinda like the inside setting of the Hughes 26' sailboat.
MG, 27' Morgan on the ICW, Love cruising at night, VA
Old 02-18-2011
mitiempo's Avatar
Do you mean the bulkhead in the pics below? If so don't, I believe it is structural and a necessary part of the boat. You will have to work around it.
Brian
Old 02-18-2011
You might get away with removing the cabinetry and the 'desktop' but I'd not remove the main bulkhead section against the settee.....
1984 Fast/Nicholson 345
Old 02-18-2011
jackdale's Avatar
jackdale will become famous soon enough
You might keep that piece to which the mike is attached. It appears to be tabbed in.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 02-27-2011
DonScribner is on a distinguished road
I wouldn't. It looks like it's helping to support the hull. But if you do, be sure to keep the lower section in line with the settee watertight. You'll probably find that if you gashed the hull below the waterline, the lockers will hold the water, saving your neck and your boat.
Old 03-06-2011
L124C's Avatar
L124C is on a distinguished road
Huh???
What do you mean, "popped up"? Does this concern anyone else?
Old 03-06-2011
mitiempo's Avatar
It should concern SailboatsRock! The hull and deck needs the bulkheads' support for strength and while they are not always tabbed to the deck they are attached in some way.
Brian
Bavaria 34 bulk head shifting problems Kenkirby Bavaria 5 03-08-2009 06:44 AM
Heads Up Nohiking Boat Review and Purchase Forum 18 05-08-2008 04:14 PM
Lubricating heads? Joesaila Gear & Maintenance 11 08-26-2007 10:16 AM
Bulk Head Diesel Heater Question? snider General Discussion (sailing related) 5 02-18-2007 02:00 PM
Lysekil Womens Match for Stena Bulk Trophy 2006 @ Sail World Australia NewsReader News Feeds 0 04-21-2006 07:17 AM
