Go Back   SailNet Community > Welcome to Sailnet > SailNet FAQ's
SailNet FAQ's This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
Old 02-19-2011
willysail is on a distinguished road
Spade rudder rebuild
In the fall I was remove my Cal 9.2 from the water when
I hit something and broke my rudder. The rudder broke about seven inches below the rudder shaft. I was wondering if any one knew of a website that had instructions on rebuilding or making a new rudder
Old 02-19-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
If the rudder shaft isn't bent you should be able to repair it with epoxy and cloth.
WEST SYSTEM | Use Guides
Lackey Sailing, LLC | Boatbuilders, Boat Restorers, and Marine Surveyors
Old 02-19-2011
the rudder completely broke off and the rudder shaft was not bent
Old 02-19-2011
CalebD's Avatar
Tartan 27' owner
I guess it is a little difficult visualizing your rudder damage without a photo.
Typically the rudder shaft will have several metal straps or ribs welded to it that would be encased in a foam core and/or fiberglass.
Are there any ribs evident on your rudder shaft? or is it just a bare pole?
Old 02-19-2011
If the blade broke below the end of the stock, then clean it all up, feather back the skin on the remaining rudder. Try to find a similar core material and fashion a new piece to match the original, undersized by the skin thickness you plan to relaminate. Maybe leave room for thicker glass layers at the joint.
Then I'd put some pins into the original part of the blade, with matching recesses/holes in the new section, slide it together and glass it all up. Then refair the repair and seal and paint it. Using epoxy resins will likely work best, but vinylester may work too. There should be plenty of on-line help as the the specifics of the materials you should use.
If your rudder stock is undamaged, there's no need to worry about the rest of the rudder unless there's some play between the original blade and the stock.. that would indicate that you've possibly damaged the internal framework or the internal coring of the original part. There is a chance, though, that if you hit something hard enough to break a chunk clean off that you have in fact done more damage elsewhere that you simply can't see....
Good luck.
If you're lucky Jeff H will weigh in with more specific suggestions.... (and likely a better plan )
1984 Fast/Nicholson 345
Old 02-20-2011
When I was removing the boat from the water for winter storage, I noticed that the rudder was very slow in responding to turns. I had used the boat the weekend before and didn’t have a problem. I was able to maneuver through the harbor and up to my mooring. When they took the boat out we noticed that the rudder was broken off. There was only about a foot of the rudder remain on the shaft. When I checked the bearings and the shaft housing there didn’t seem to be any cracks or weeping of water. The shaft seems to turn easy without any binding or stiff spots. I like the idea of mending the rudder
I have, the only problem is will it hold up.
Spade rudder - Ocean passage Minnewaska General Discussion (sailing related) 6 12-08-2010 07:17 AM
Gibsea 43' Rudder Rebuild/Replace Help jkemp SailNet FAQ's 1 04-19-2010 10:25 PM
spade anchor kimberlite Cruising & Liveaboard Forum 1 11-16-2003 04:40 PM
Spade Anchor Visigoda Cruising & Liveaboard Forum 7 05-03-2003 12:11 PM
THE SPADE ANCHOR bobcon Gear & Maintenance 0 09-25-2001 04:31 PM
