06-18-2011
Crotchety Old Member
I may agree with kd3pc. You'd be surprised at how quickly your amp hours add up. Recently when I started to design a solar panel setup for my boat, I put together a spreadsheet to calculate what is needed. It takes into account the average daily sunshine, inefficiency of some of your appliances running through an inverter, daily usage of appliances, and a few other things. Then it calculates how many amp/watt hours of energy your panels will put out and tells you whether you have a deficit or a reserve of power.
You really need to plan ahead. If you have a refrigeration system you have to calculate the efficiency and should log real-world usage. Your laptops can be a real drain, too. A coffee maker, although takes a LOT of power (900+ watts) and you would think would be a big drain, doesn't really drain all that much because it is used infrequently. Again, you'll be surprised where all your power goes when you calculate it out.
Capt'n Tom Living Aboard 50/50
S/V Footprints
1969 Crealock/Columbia 36 Sloop completely refitted in 2000 and new Yanmar in 2006.
Hey, if I can't be sailing at least I can be here!
