Go Back   SailNet Community > Welcome to Sailnet > SailNet FAQ's
SailNet FAQ's This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
Old 07-24-2011
Skippy1 is on a distinguished road
Through hull not working
I haven't worked with through hulls much up to this point but my galley sink drain is not draining and it looks to be plugged at the through hull. The valve opens and closes OK but doesn't drain. DO I need to replace it? I was hoping there was an easier solution. Any help would be appreciated. Thanks
Old 07-25-2011
mitiempo's Avatar
If the valve is open and still plugged first try a plunger in the sink to blow any obstruction out. If that doesn't work remove the hose from the sink and use either a rod or smaller hose to push down to clear the line.
Brian
Old 07-25-2011
aeventyr60 is on a distinguished road
Fill the sink half full of hot soapy water, see if that will help unclog the drain. Another thing is to get in the water with a coat hanger and push it up the through the thru hull (gently).
After those two, take off the hose, probably grease, coffee grounds and other gunk.
"Your dreams minus your doubts equals your net worth"
"Life favors the Fearless"
Old 07-25-2011
through hull plugged
This looks like sound advice - I'll give this a try....thank you
Old 07-25-2011
mitiempo's Avatar
There should be no reason to have to clear it from the outside.
Brian
Old 10-18-2011
Capt Len is on a distinguished road
Shut the valve. Remove hose. Slowly open valve.If water flows, shut valve and clean or replace hose to sink.If the valve is not a proper ball type make it so. but that.s another story
Old 10-19-2011
chris_gee is on a distinguished road
Not a good idea - it sometimes happens that the valve will not shut.
Old 10-19-2011
Just checking. Does it have a pump to get the water out?
Tags
through hull problem
gps not working katthater Electronics 3 06-17-2009 06:15 AM
Multi-Hull vs Mono-Hull Sailboats? terryjoe Boat Review and Purchase Forum 8 11-11-2007 10:45 AM
Do you paint over thru hull bronze nipples on hull saurav16 Gear & Maintenance 4 08-19-2007 06:15 PM
Working Jib jsheler Chesapeake Bay 1 06-12-2006 06:25 PM
Working and Cruising Doreen Gounard Cruising Articles 0 10-29-2003 07:00 PM
