Go Back   SailNet Community > Welcome to Sailnet > SailNet FAQ's
SailNet FAQ's This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
Old 10-02-2011
ppenoyar is on a distinguished road
prop shaft removal
I have a new to me 1978 Catalina 27. Came with a transom bracket and 8 hp johnson outboard. The original inboard atomic 4 died long ago. I was never going to repair or replace this so I removed it. The only thing left is the prop shaft. Since this is bsolete now, I want to remove this while I have her out of the water to bottom paint. The prop is well stuck on the shaft. I was thinking of cutting the prop off the shaft. If I did this would I be able to pull the shaft from the inside of the hull? Any ideas on getting the prop shaft off in the easiest manner keeping in mind I have no deed for this?
Old 10-02-2011
jrd22's Avatar
Courtney the Dancer
Sawzall. Just keep cutting pieces off the shaft if it won't go past the rudder.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 10-05-2011
luck66 is on a distinguished road
The shaft may be pulled off the boat from the outside. Thats how I replaced my shaft, I used a diver and when he pulled the shaft out I put a plug in the hole where the shaft was. I replaced the shaft. It mighr br a real job to cut the stainless steel shagt.
Shaft removal on a Beneteau 461 dillybar Gear & Maintenance 0 08-02-2011 08:46 PM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 2 11-28-2009 02:19 PM
Prop/Prop-Shaft Key Size? Skipaway Gear & Maintenance 7 07-29-2008 09:04 PM
Prop removal imiloa Gear & Maintenance 7 02-25-2008 07:07 PM
