Go Back   SailNet Community > Welcome to Sailnet > SailNet FAQ's
SailNet FAQ's This forum is specifically on the Sailnet Website and how to do certain things on the website. Please note - any other threads will be deleted.
Old 11-18-2011
aailswor is on a distinguished road
Question Bristol 32 gearbox
My Bristol 32 has a 27A Westerbeake with a Hurth gear and the forward gear is slow to engage and has to be handled very carefully. It looks like a new clutch pack is required. Has anyone ever removed the gear without having to remove the entire engine. I replaced the fuel tank several years ago, and it is designed to be removed very quickly which will help with access to the gearbox area.
Any suggestions would be appreciated.
Thank you.
Al
Old 11-18-2011
Capt Len is on a distinguished road
If your motor mounts are on the gear it will need a block of wood under the bell housing for support. Disconnect shaft flange and slide it back a bit. Unbolt mounts if needed and support engine. If mounts are are on the engine simply unbolt gear and work it back so the splines disengage. It will drop about now so needs support . It's not that heavy but if you are working at arm's length,take care. Option is to move whole engine out where you can get at it.
Old 11-30-2011
Thank you for your valuable information.
Old 11-30-2011
Rozz is on a distinguished road
can u do a write-up on this? im going to be doing the same with my bristol very soon... id rather learn from u breakin' or smashin' stuff then me lol j/k
1967 Bristol 29 #35
Old 11-30-2011
oh and maybe some use out of our Bristol forum!! yay!
1967 Bristol 29 #35
Raymarine MK-2 Wheel Drive Gearbox windseeker33647 Gear & Maintenance 0 10-31-2011 12:06 PM
Noisy Gearbox................??? yohoho Gear & Maintenance 8 01-29-2010 06:39 AM
Volvo 2003 gearbox j34035 Diesel Engine Forum 1 01-24-2010 05:15 AM
Gearbox problemo......HELP ! bettyswollocks Gear & Maintenance 14 06-26-2008 01:37 AM
gearbox ratio dhornsey Gear & Maintenance 1 04-21-2008 10:07 PM
